How long is a full cycle for the Dolphin e10?
Just bought this dishwasher water is connected correctly as per manual though after 1 min into cycle E10 error
Hi, check and make sure you have the water supply turned on full to the dishwasher as some times folk don't turn the pressure on full and also make sure you don't have any kinks in the supply pipe . If the water supply is ok and the unit has got warranty call them out.
Feb 14, 2016 | Washing Machines
Dolphin pool cleaner stops working after a 15 to 30 minutes. Even though the cycle time is set to 8 hours. How can I fix ?
It sounds like you might have a problem with the impeller or drive shaft, which are both common problems with these pool cleaners. Clean around your impeller and your wheels, axles, etc. If these do not cure your problem, it is probably an issue with your electrical system.
Jul 30, 2010 | Dolphin Maytronics Advantage
Dolphin pool cleaner cleaning cycle
The motor pack is failing and will need to be serviced which is not a do-it-yourself sort of project. Of course that may not stop you from trying but you will find that parts are not available inside the motor pack and that replacing it, if necessary, is best done in a service center to maintain new motor warranty. For price estimates on a replacement or to browse a FAQ on dolphins check out our site at www.arrowpools.net or you can contact the manufactrure's US rep at www.maytronicsus.com.
Jun 14, 2010 | Dolphin Maytronics Advantage
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
E10
Are you using HE or high efficiency detergent? E10 code can also indicate over sudsing caused by standard detergents. Also, standard detergents, due to over sudsing can cause long washing cycles as well. This sounds like your problem.
Jun 07, 2009 | Frigidaire ATF6000ES Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi progress 1200 WASHER DRYER
This means that the filter is clogged. Get a towel (or two) in our case, and then unscrew the filter. It'll be full of lint.
Dec 26, 2007 | Washing Machines
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
