Question about Dryers
I replace the Gas coils and still doing the same thing
The machine completely shut off (dead) even if I unpluged it, I can not turn it on, but may after an hour turns on like nothing happend (I was thinking The problem is the Main PCB but I call to place an order for my surprice (2 companys) this PCB is discontinue
Samsung Model DV306LGW/XAA.
If somebody can HELP ME....
Thanks
  • 6,784 Answers
HI. i have located a PCB that is available for order if you wish. just click the link below to be directed to the order page.
CLICK HERE
Posted on Jul 25, 2009
B/s 4'5 hp/start then sputters for about 3 min. then shuts down/changed oil,plug
could be a number if things, dirty carb, old gas, dirty coil contacts, low combustion chamber pressure, (bad rings), bad spark plug. First try replacing the spark plug and if it is old gas remove and replace with fresh. if that doesn't do it then the carb needs to be removed, cleaned and blown out thoroughly with an air compressor. reassemble and reinstall. next is to remove the recoil housing and clean the coil contacts. the coil is attached to the spark plug wire. remove and with some old gas or wd-40 and a wire brush, remove dirt and rust from contacts as well as magnet on the flywheel. be sure to leave the proper gap between the coil and flywheel when you replace the coil. If you can pull the recoil with your forefinger and thumb, chances are your machine is toast and needs a ring job. good luck
Aug 06, 2014 | Mtd 22" Yard Machine Push Mower
Washer starts to fill then shuts off.
First, turn it off, and completely unplug it, then plug it back and turn it on if it continues to do the same thing replace the fill valve on it, just always make sure your safe when working on it or whatever your doing let me know im interested thks hope this helps
Feb 19, 2010 | Washing Machines
My refrigerator GE TBX22ZA makes a banging,(thumping sound)when it shuts down, A PROBLEM?
Good day,
On GE products it's referred to as a rattle down. It is internal to the compressor, and short of a new one, little can be done.
They will many times run a long time before failing, even years.
The only thing you can do, is make sure the condenser coils are clean. Vacuuming doesn't always work. You need to unplug the machine, remove the back cover, and blow the coils out from back to front, and then front to back.
Ugly and dirty, but should be done. A good shop vac with a push/pull feature and crevice tool works great, if you don't have a compressed air tank.
Second, make sure the cooling fan by the compressor is running properly, and lastly Make sure you reinstall the back cover completely. IT IS A VITAL PART OF THE MACHINE.
Thank you for using FixYa
Feb 02, 2010 | Kenmore 26.0 cu. ft. Side-By-Side...
Flame turns on only when dryer is cold, runs for 10 minutes then burner shuts off. The coil glows very bright but the flame does not come on again until dryer has colled way down
The gas valve coils are bad. When they heat up they are losing resistance to stay on.
Turn off the gas. Unplug the machine. Remove the front panel. The gas valve will be in the front right hand corner. Remove the gas valves and replace them with new valves. Please note how the coils orient on the gas valve.
Dec 02, 2009 | Whirlpool GGQ8831L Gas Dryer
MY husband replaced coils on top of gas valve. He
is it completely dead now or does some things still operate??? and what make is the dryer?
Oct 05, 2009 | Dryers
Have a Brother Intellifax 770. Machine went completely dead
Probably fried. Sounds like more of a power surge than a paper jam.
Apr 07, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Gas Dryer not heating
You will have to replace "BOTH" of those gas solinoids. First, be absolutely sure that you "TURN OFF THE GAS". Then be sure the unit is unplugged. Remove the phillips head screws, remove the small metal top bracket, and slide the coil up and off. Then replace the coil, rehook your wire, and replace the metal holder. Upon testing, be sure to turn your gas back on. The first time it may act like it wont start, but let it cycle through a couple times to remove air. Good Luck And Be Safe. Jim
Sep 07, 2007 | Kenmore 72062 Gas Dryer
Replace oil roller
Reset the machine by turning it off, completely unplugging it, all cables and cords. Leave it awhile (go and have a cuppa) now replug all and switch on.
Aug 31, 2007 | Minolta magicolor 2200 DeskLaser Printer
Dryers Logo
250 people viewed this question
Top Dryers Experts
