Question about APC Computers & Internet
I have APC RS 600 and it's powering on but relay is making continuous sound tttrrrrrr.....
  • 7 Answers
SOURCE: APC Smart-UPS 1000VA is powered on but not working
Try turning the unit off for a little while, unplug it from the source even. afer about 5 minutes plug it back in and try it again. You may have a bad battery, how old is the unit. UPS batteries should be changed out every 3 year's, max every 5 year's if you want good reliability. At 5 years you are taking a chance.
Posted on Jan 25, 2007
uk8ahw
  • 3 Answers
SOURCE: ups is not glow any indication, just give buzzer
It look like dead battery. Try to connect carefully new (or allmost new) battery with 24v lamp in (+) wire. If UPS alive - you'll see only small momentary sparcle. After this - connect battery as usual and try to turn system on. Be carefull! If lamp lit in full power - it means a serious internal problem. Best solution - look for qualified serviceman. (maybe yoir system needs reprpogramming).
Posted on Apr 14, 2009
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
SOURCE: APC Back UPS RS-1000 Overload LED with beeping sound after on.
in the end solution is you have to bring it nearest apc service.
if you loaded more than its max. capacity at past, the sensor of power is geting burn the sequare wave generator IC.
so you need help with that, olso complicated.
I live the same position with my rs1000, horrible :((
Posted on Jan 09, 2010
What causes damage to the IC called TNY275PN in APC RS 600 UPS??
Buy the APC SMART UPS 1000VA or higher. Those can allow setting of norminal voltages and boost or buck limits. The Boost and buck of Smart UPS function like an Automatic voltage regulator.
The cheaper UPS are built for nominal voltage of 230V +- 10% and cannot be changed. Overvoltage is cause of your UPS failure.
Jun 16, 2014 | APC Back-UPS 600VA UPS System
I have APC RS 600, 360W battery which is not working that means O/P voltage 230V is nill there is no Output supply . I checked the ckt but when switch on the ups it will start alarm and even i check the...
Hi Datta,
It seems that you have the wrong battery in that UPS. The replacement battery for that unit should be an RBC2 -or- a 12v 7.5ah battery ($28 delivered). The UPS will not work without the correct battery in place.
If you could provide me with the exact model number I may be able assist you further.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
** If this helped - Give it a Thumbs Up :) **
Dec 13, 2013 | APC Back-UPS 600VA UPS System
Our ups apc back-ups 1500 is making beeb sound with red led blinking (overload option)
remove the load fom the ups and restart the ups. if the ups alarms again then the problem is in the inverter.
Apr 19, 2011 | APC Back-UPS RS Battery Backup (apw...
I have an APC Back up 800 but when I plug it in it does not do anything. How can I troubleshoot and fix this?
first make sure it is switched on -- and -- that there is power to the receptacle which you are plugging it into - if not, try resetting it.,.
Ck
Feb 13, 2011 | APC Back-UPS RS 800VA UPS System
Jun 11, 2009 | APC (br800) UPS System
Ups is not glow any indication, just give buzzer sound , APC make 2000va RS model kindly tell me what i can do to repair it.
Apr 13, 2009 | APC Back-UPSĀ® CS 500 UPS System
Beeping error
on the heatsink thats in front the fans theres six fet irfb23n20d mine had the outer two towards the fan short circuited.replaced them and all is well now.
Oct 24, 2008 | APC Back-UPS RS Battery Backup (apw...
Jan 18, 2007 | APC Smart-UPS 1000VA UPS System
Computers & Internet Logo
43 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
