Question about Samsung Washing Machines
Samsung front load 7.5 kg has 4e error.....checked all hoses and water pressure ok. error returns on restart and will not continue cycle. tried power off and on many times
SOURCE: Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Posted on Apr 17, 2008
  • 3 Answers
Had the same problem - I posted full description in another 4E post - But my problem was a crack.split in the pipe to the sensor
Posted on Jul 11, 2008
SOURCE: 4e code
i have problem error 31( E31) please advice me to solve this problem
Posted on Apr 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: 4E showing on Samsung Washing Machine
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a samsung 7Kg
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
4e on my samsung front load WF42H5000AW
A 4E code indicates your machine is not sensing that it is filling. The corrective action is to check that water supply is on and has adequate pressure, hoses are not kinked, and that filters on the inside end of the water valve are not clogged.
Nov 21, 2016 | Samsung Washing Machines
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
My fontloader samsung wassingmachene p843 giv me and error code e3 4e and5e
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 22, 2012 | Washing Machines
Describe your 4E problem in samsung front load Problem
Thanks for using FixYa!!
Sep 19, 2010 | Samsung WF203ANW Front Load Washer
2008 Samsung front end loader develops a 4E error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Error 4E + timer countdown is delaying
Sep 02, 2009 | Samsung WF337AA Front Load Washer
4E error....samsung J845
Aug 23, 2009 | Samsung WF203ANW Front Load Washer
Apr 06, 2009 | Samsung WF337AAL Front Load Washer
Samsung washer
Jan 28, 2009 | Samsung WF337AA Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
