Can I fix my Emilia EDW62SS dishwasher? - will not continue cycle after sounding as though has filled initially, then stops with the rapid program light flashing & beeping.
  • 58 Answers
SOURCE: Frigidaire Dishwasher Console/Lights Flashing
which light flashes?
Posted on Nov 02, 2007
Poohs
  • 4 Answers
SOURCE: BF162 Hotpoint intergrated dishwasher
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
  • 134 Answers
SOURCE: Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Posted on Feb 14, 2009
SOURCE: IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Posted on Nov 01, 2009
joe_lishman
  • 192 Answers
SOURCE: HOOVER HOD6615 DISHWASHER CONTINUAL BEEPING AFTER
This could be a safety trigger due to bottom water leak. A anti flood device (polystireen float and micro switch) that switches washer in shut off mode and does not continue until the water leak (pipe or hose clamp) that causes the float to trigger the device. Check the bottom of the washer for traces of water and rectify any leak before the washer will continue.
Posted on Jun 01, 2010
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
My Bosch SHU9925UC dishwasher will not stop cycling and come to an end. I also noticed that a couple of weeks ago it stopped beeping to signal the end of the wash. Can anyone help me please? Thanks for...
From the Appliance Repair Clinic:
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
* On some units, the pause is timed and the unit continues after the allotted time.
* On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Jul 20, 2008 | Dishwashers
Our bosch SD13J1B don t switch on. Water incom is OK. Electrisiti is too OK.
Possible that the program controller unit can be faulty if the cycle is not initiated after the water is filled into the unit. Now does the water stops after the initial filling? If not the pressure swtich must be checked. Also the door switch, the connections to the washer must be looked into to ensure that all contacts are intact to the program controler. If the washer still wont work then the Program controller is a prime suspect.
Nov 05, 2010 | Dishwashers
Maytag Dishwasher - MDB6650AWW wont fill after initial fill
sounds like a bad module control. let me know if this helps with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Cycle won't advance out of initial draining mode
There could be many reasons, but the 2 most possible would be :-
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2009 | Bosch 24 in. SHV4303 Built-in Dishwasher
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
FDW60 has standing water in the bottom and will not fill up
You most likely have a stubborn clog in your kitchen drain. Try filling the sinks with warm soapy water and then letting the water drain while also turning on your garbage disposal. Sometimes the extra water pressure will help push the clog through.
Jun 16, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Bosch shu5315 06
it sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Jun 05, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
