Question about Car Audio & Video
Plz tell me it's input Watts power and ohms details
  • 3 Answers
SOURCE: amp getting really hot
If depends on what the amp is rated to run. If it is only rated to run 2 ohms x2ch then it can only run 4 ohms x1ch. If you run it at 1 or 2 ohms that is too low, too much current, and it will get hot and eventually blow up under hard use. Some quality amps can live that way, and it depends on the sub and what frequency you are running it at. For normal use I would not recommend it. Wire to sub at 4 ohms x1 (or 2 ohms x2ch) for that amp if that is what it is supposed to be at, I'm not sure from your description. Also enhance cooling of the amp if you can, I run fans on mine if they have a heat issue. Warm is one thing, hot is another and not good for amp.
Posted on Apr 22, 2008
SOURCE: Subs and amp problem
2 subs and 1 amp
Posted on Nov 19, 2008
  • 655 Answers
SOURCE: Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Posted on Jun 03, 2009
  • 4 Answers
SOURCE: i have the Sony XS-L120B5D subwoofer with
sounds like you are out of phase, just reverse the wires for ONE of the woofers and that should do the trick. just try it, it will amaze you!
Posted on Jun 26, 2009
  • 15 Answers
SOURCE: need help wireing sub
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Posted on Oct 09, 2009
I have this subwoofer eclipse 800 watts peak, 8 ohms , and i would like to know if the alpine pdx m6 can deliver 600 watts rms at 8 ohms too, o just at 4 o 2 ohms, i will appreciate your help.
No. It is optimized to deliver 600 watts onto either 4 or 2 ohm loads but will decrease to 300 watts into 8 ohms. However that equates to only about a 3dB difference in output level from the sub. 3dB is the smallest amount of volume difference the human ear can pick up. A doubling of volume requires a9dB increase which requires a tripling of input power.
Aug 09, 2016 | Alpine Car Audio & Video
How can i tell how many watts my fosgate 351m power amp is?
Specifications Dynamic Power Rating (measured at 14.4V):
  • 4-Ohm Load: 175 watts x 1
  • 2-Ohm Load: 350 watts x 1
Jan 29, 2013 | Rockford Fosgate Power 351M Car Audio...
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
I have the following specs for you
Basically 150watts per channel using two channels , or 75watts using all four
Here goes:
  • 4 Channel Mosfet Amplifier
  • Advanced Overload and Thermal Protection
  • Metal Film Capacitors/Resistors In Signal Path
  • Frequency Response +/-1dB, 20Hz to 20 kHZ
  • Signal to Noise Ratio (A-weighted) >100dB
  • Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
  • Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
  • Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
  • IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
  • Minimum Load when Bridged 2 Ohms
  • Minimum Load per Channel 1 Ohm
  • Input Signal Voltage Range 0.1 volts to 2 volts
  • Crossover Type Resisitor Network, Linkwitz Riley,
  • Highpass/Lowpass
  • Crossover Slope 24 dB per octave
  • Crossover Frequency Range 20-550Hz
  • Factory Crossover Setting 85 Hz
  • Auxilary Output Channels 2
  • Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
  • Bass Boost 0- to +18dB @ 45 hZ
  • Power Supply Voltage 10Vdc to 15.5Vdc
  • Recommended Fuse 40 amp
Dimensions 12.25L x 9.25W x 2.10H
May 23, 2010 | Car Audio & Video
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
How many watts is it
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
The MRD-M300 has speaker-level inputs so you can easily use it with any car stereo. Hook it up and hear what good bass can sound like!
  • 150 watts RMS x 1 at 4 ohms
  • 300 watts RMS x 1 at 2 ohms
  • MOSFET power supply and output stage
  • STAR Topology for cleaner sound
  • Bass Engine® features:
    • low-pass digital crossover, 30-200 Hz, 24 dB/octave
    • variable subsonic filter (15-50 Hz in 5 Hz steps)
    • parametric EQ variable from 30-160 Hz
    • Bass Compensator enhances low-end definition
  • top-mounted digital control center with cover
  • time correction 0-10 milliseconds in 0.5ms steps
  • phase correction 0-180° selectable
  • digital readout
  • detachable front cover
  • blue power LED
  • delayed turn-on
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • speaker- and preamp-level inputs
  • gold-plated terminals
  • 8-5/16"W x 2-11/16"H x 11-1/2"D (10"D without front cover)
  • 1-year warranty
May 29, 2009 | Alpine MRD-M300 Car Audio Amplifier
What are the correct spaekers for the gm 5100t ?
    CEA-2006 Compliant Amplifier Power Standard:
  • 125 Watts x 2 @ 4 ohms <= 1% THD+N
  • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
  • 75 dBA Signal-to-Noise Ratio
  • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
  • 2 Channels
  • Continuous Power @ 4 Ohm: 125W x 2
  • Continuous Power @ 2 Ohm: 190W x 2
  • Continuous Power Bridged @ 4 Ohm: 380W x 1
  • Frequency Response: 10Hz-50kHz
  • THD (1kHz, 4 Ohm): <0.015%
  • Signal to Noise Ratio: >95dB
  • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
  • PWM Regulated MOSFET Power Supply
  • Balanced Isolator Input Circuit
  • Oversized Screw-Type Power/Ground Terminals
  • 2 Channel RCA Inputs
  • Speaker Level Input
  • Screw-Type Speaker Terminals
  • Hi-Volt Input Level Control (200mV-6.5V)
  • Bass Boost (50Hz, 0/6/12dB)
  • Selectable LPF (80Hz, -12dB/Oct.)
  • Pioneer 1-Year Warranty
I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
