Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer "grabs" only a corner of the paper, then cannot pull it completly into inside
  • Canon Master
  • 739 Answers
Also check that the paper guide in the feed tray is tight up against the edge of the paper. If it is not, the paper can skew as it is picked up and then jam on the way in.
Posted on Jul 27, 2009
  • 28 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-23
Posted on Sep 04, 2009
    Master:
  • 409 Answers
Try cleaning the rollers that pull the paper. use a piece of tissue and some cold tap water.
Also make sure that the paper tray is full
Posted on Jul 24, 2009
When the paper is fed it is pulled in w/ the bottom right side of the paper going in but not the left side, it becomes uneven and ends up jamming - what would be the reason it would grab and pull the right...
The most likely cause of the problem is an obstruction on the left side of the paper path - most likely a shred of paper from a previous jam. You can estimate where to look by how far the paper goes in before it starts to twist to the side. Sometimes I've had to use a dental pick to snag a shred buried deep inside as an alternative to dismantling the printer. You may find it helpful to use a small mirror to look underneath or behind rollers while you search for the culprit.
Another possibility is one side of a dual pickup roller (two rollers on a single shaft) is worn out. That is unlikely; except for large format units most printers use a single pickup roller.
Jun 06, 2011 | Epson Stylus CX9400 Photo Printer
Can see the paper jam from the back at the top - folded tightly, no way to grab a corner, how far can it be taken apart? No moving parts visible.
It'd probably be better to get pliers or tweezers to pull the paper out from the back, instead of trying to take the printer apart further.
Jun 06, 2011 | Dell 1710n Laser Printer
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How to remove jammed paper in the Samsung ML-2240 laser printer
If there are papers stick out of the top in the recieving tray gently wriggle them back and forth until they are free. Then, open up printer and the remove the ink cartidge. The papers lying mostly on the inside need to be pulled from the inside. The papers that have just been picked up and are mostly still lying in the paper feeder can be pulled out from there as well (although you may want to remove all the paper that hasn't been grabbed yet). Just keep wriggling back and forth gently so as not to tear the paper and lose a little scrap inside.
Oct 06, 2009 | Samsung ML-2240 Laser Printer
My MX310 got a paper jam and when i pulled the paper out a small piece of the corner tore off and is still stuck in the printer. The printer now continues to claim there is a paper jam but i cant visually...
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
Jun 05, 2009 | Canon MX310 Office All-In-One Printer
Grabbing the paper pulling it in at the left hand side
1) Try to adjust lateral directing limiters for paper.
2) See attentively inside device no there stranger subject such as pencil or piece of the torn paper. Use the lighting of the lamp or flash-light.
Mar 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Putting out extra sheets
Do you "fan" your paper when you fill the machine? paper will adhere together, unless you " grab any corner of the fill, pull towards that same corner to allow air to get between the sheets.
Feb 04, 2009 | Brother MFC-8840D All-In-One Laser Printer
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Paper jam R240
A qualified - manufacturer certified servicer is needed here. Your are correct, the missing piece is still inside and also, yanking-out a paper (while it is being fed by the printer) will have a definite damage on the paper-feeding mechanism.
In-warranty or not - u need to call the manufacturer.
Jun 13, 2008 | Epson Stylus Photo R2400 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
127 people viewed this question
old marine
old marine
