Question about Whirlpool Kitchen Ranges
Whirlpool oven 476 - gas ignited but goes out. New oven or worth gas expert having a look?
    Top Expert:
  • Whirlpool Master
  • 49,327 Answers
Could be a problem gas regulator
ring first and get a quote for a service call then add that to the price of a new unit and see if the repair is well less than a new unit
Posted on Apr 23, 2017
Westinghouse px 650 gas wall oven wont re ignite once initial heat is met
what you should be doing next is to get a gas fitter out to determine why the pilot light is going out or the sparker is not lighting the gas
gas is not a diy operation as a mistake from you could destroy the building and yourself
Dec 15, 2016 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
Is there a pilot for the oven that can go out and needs to be manually relit? I have alrady replaced the igniter
The Whirlpool SF357 (SF357PEKQ0 specifically) does not have a pilot light; only the electric igniters that light the gas on demand for both the range and the cooktop.
On my gas ovens, checking the ignition is easiest with the warming drawer removed and the cover plate removed from the oven. Do you see a glow at the igniter? If yes, then the igniter is probably working. If not, check that the wiring harness between the igniter and the control board is connected and giving the appropriate power.
The next thing to check is that the oven gas valve is open. (Mine have a separate valve here.) Then check that nothing is blocking the gas line and that the regulator is opening and closing properly. We had an old oven that would start the gas flow and come up to temperature normally during the pre-heat time. However, when the oven cooled, the regulator wouldn't reopen thus the oven wouldn't stay at temperature. The regulator could be forced to open with a tap to the mechanism when the oven needed to come back to temperature.
Whirlpool has manuals and parts lists for the SF357 ranges on their site. https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10561&langId=-1&storeId=10211 . The installation guide is here: https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%208273169.pdf . The owner's manual is here: https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208522776.pdf .
I hope this helps.
(In the case of our old oven, we replaced the entire range. The difference in price between a new range and the needed parts (and labor) to fix the old one were nearly the same.)
Nov 12, 2011 | Whirlpool SF357 Gas Kitchen Range
I have a westinghouse 476 gas oven, the oven does not turn on all the time the ignitor heats up but no gas comes out. when i take the cover off the ignitor and tap on base of oven it ignites and works...
It sound like you have a valve problem some types of ignitors have a heat release valve, by hitting it you cause this to release, I would suddjest replacing the ignitor unit but this requires a Gas Fitter that is approved, as all sorts of tests, requires specialised equipment, if you have gas central heating, the service engineer could perform the same for your cooker. remember to ISOLATE MAINS POWER if this model uses it for ignition.
Hope this has been helpful
john
Jun 06, 2011 | Ovens
I have proble with whirlpool gas range SF265lxtq When I tried to use the oven, I setup the oven by the keypad, but the oven does not get hot, and i did not smell gas. What should I do ?
Your Direct Spark Ignition System contains a
Gas Distribution Valve and a Direct Spark Ignition
(DSI) Control that interfaces with the
Electronic Oven Control, and spark electrodes.
This provides the direct spark ignition and gas
distribution for Whirlpool self-cleaning gas freestanding
ranges. You must familiarize yourself with this system
before attempting any repair. Look through this service
repair manual for direct spark HERE
Mar 01, 2010 | Whirlpool SF265LXT (Gas ) Kitchen Range
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Whirlpool Oven will not light Model SF385PEE Help its Turkey time
i would check the wiring tothe gas valve, sounds as if you wired incorrectly
Nov 21, 2008 | Whirlpool SF325 Gas Kitchen Range
Converted to LP Gas,How to adjust top & bottom flames in oven?
Open the air vent to the burner, you may have a small delate when it goes on , make sure the burner is clean buy the ignition, or the ignitor it's goin bad, you will know that when the oven takes more then a minute to ignite.
Nov 19, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool SF365pegq
The way the ignition system in most of today's ovens work is like this:
1. Set the oven or broiler temperature.
2. The igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
5. NOTE: It can take roughly 30 - 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) - needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) - needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn't light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it's an easy assumption to make that the igniter may be bad, if one or the other doesn't light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn't produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won't light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we're going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
2. Open oven door and remove (if possible). Refer to your owner's manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn't shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
8. Reconnect the wires using the recommendations mentioned in Step 5.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 - 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2008 | Whirlpool SF369 Gas Kitchen Range
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
