Fixyahttps://www.fixya.com > Forum > Heating & Cooling
Aug 9, 2021 - Zamil 2 ton non inverter split type e7 error what is the problem !? ... There is a mode conflict. Some units are calling for heat and one is calling for cooling.
The C1 error code on a Samsung digital inverter AC usually indicates a communication error between the indoor and outdoor units. This could be caused by a faulty control board or a wiring issue.
To troubleshoot this issue, you can try resetting the unit by turning off the power supply for a few minutes and then turning it back on. If the error persists, you may need to call a professional technician to diagnose and fix the issue. They may need to check the wiring connections and replace any faulty parts if necessary.
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
C1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor
