Question about Dishwashers
Dishwasher small black overflow pipe runs up past the salt chamber / water intake and empties into the tray under the dishwasher. What is this pipe and what would cause the overflow?
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
grandadfixer
  • 99 Answers
SOURCE: Salt tray full of water
Just pour a bag of dishwasher salt in water will come out.Then light goes out.
Posted on Oct 12, 2008
  • 93 Answers
SOURCE: Water overflowing out of dishwasher
I see you do not give a make and model so a few possibilties here .Chances are that something has gotton stuck in the drain pump stopping the impellar from turning I suggest you get a technition in to look unless you are technical yourself,worst case being the drain pump itself is broken in wich case replace it (NB If your machine has a timer the timer may also be fualty)
Posted on Jan 21, 2009
SOURCE: water keeps running into dishwasher causing overflow
I had a diswasher with thils problem several years ago. The problem was wiith the plastic float at the bottom. It had hardend greese buildup that kept the float from moving freely. Removing the float and cleanning fixed the problem.
Posted on Jan 29, 2009
SOURCE: Mieli water-intake light comming on?
THIS IS THE INTAKE DRAIN LIGHT, THIS USUALLY MEANS YOU HAVE A DRAIN ISSUE, COULD BE A BLOCKAGE AT THE PUMP OR YOUR INSTALLATION IS INCORRECT, YOU CAN CALL MIELE CUSTOMER SERVICE AND ORDER A USE AND CARE MANUAL AS WELL AS AN INSTALLATION GUIDE, THEY ARE ALSO VERY GOOD AT TROUBLSHOOTING OVER THE PHONE @ 1-800-843-7231
Posted on Mar 12, 2009
I have a miele G841 dishwasher and the saftey pan is always filling up with water and then a intake - drain error code comes up and the dishwasher will not allow water to enter for rinse until I drain...
Hi dear.If you are handy enough,that's what you can check to make a solution for yourself.Goodluck.
Check all hoses, connections and threaded unions for leaks.
Note:
If the leak source has not yet been detected, check the following areas
in the toekick and the drip pan for wear and tear:
�� Connection between the circulation pump and the sump
�� Axial face seal of the circulation pump
�� Connection between the drain pump and the sump
�� Connection between the salt container and the water intake
�� Connection between the water intake and the cabinet side wall
�� Overflow (e.g., excess foam formation)
�� Water level between the overflows (�� seating of the lower door seal?)
�� Connection between the cabinet and the salt container
�� Non-return valve in the sump (�� water running back from the drain hose?)
3. Check overflow float switch B8/3 for continuity and correct operation.
4. Carefully dry all electrical components in the drip pan area.
Cause:
Float switch defective.
Remedy:
Replace overflow float switch B8/3.
I hope that helps.Thanks.
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Diswasher Pump won't stop running
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills, OK, then this ISN'T a solution to your problem.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
May 04, 2009 | Bosch Dishwashers
Siemens Lady 45 Dishwasher - Starup and Water problem
try unblocking the inlet hose under the machine.. My machine was overflowing inlet water into the tray under the machine setting off the above mentioned aquastopper switch. I removed side pannel, then one end of the inlet hose under the machine and dragged a wire with cloth tied to end through, removing a serious amount of built up scum. no more overflowing!!
Mar 13, 2009 | Dishwashers
Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Feb 11, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Water keeps running into dishwasher causing overflow
Jan 29, 2009 | KitchenAid Dishwashers
Bosch Dishwasher model : SHV4313GB/17 The machine won't switch off and the pump is still trying to drain water ( there is no water left in machine ) The cycle seems to have finished as it has made the...
I have a SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Good luck.
Montpelier Man
Mar 08, 2008 | Dishwashers
Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Aug 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Aug 05, 2007 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
Top Dishwashers Experts
