Question about Video Game Consoles & Games
Why is one of my games not accepting normal English words and the board reads 2P 3P 2L 3L instead of the usual DW TW DL TL . What has happened
2 Suggested Answers
  • 7993 Answers
SOURCE: how do i enter linear
You can enter equations of any type. Read the rest of the post. Keep in mind that if you are using the Solve( function X must be the unknown. If you are using the Table computational mode, X is the independent variable and Y the dependent one.
The variables you have at your disposal in this calculator are
A, B,C,D,X,Y,M. All of them are accessed by pressing the [ALPHA] key before the key near which is written the name of the variable. You will notice that the markings of the symbols accessed with the [ALPHA] key are of the same color as that of the [ALPHA] key.
You will notice also that there are two = signs.
The one at the bottom right executes the command line. By pressing it you find the result of the expression just entered.
The other = sign is marked on the body of the calculator with the same color as the [ALPHA] key. It is located at the top left of the keyboard (excluding the row with SHIFT, MODE, the navigation buttons)
Example to enter X^2-2X-35=0 you proceed as follows.
Direct access physical keys are in [ ],
[ALPHA] (X) [X to power 2] [ - ] [2] [ * ][ALPHA][(X) [ - ] [3][5] [ALPHA] (=) [0]
Usually when you enter such an expression it is with the intention of solving it for X. By default X is taken to be the UNKNOWN. You will be prompted to enter the value assigned to any other letter symbol (Y, A,B,C,D).
So, if you want to use the Solve function, you enter the equation you are dealing with, and before pressing anything else, press [SHIFT] [CALC] and the calculator will ask you a question: "Solve for X?" , and you press the = sign at the bottom right.
Then you will be prompted for any other non-X letter. Once all non-X variables (if any) are given values, the calculator will return with the solution. You will see on the screen L-R= (should be zero if you are lucky).
Posted on Nov 16, 2010
How can I fix Microsoft Office Word 2007 for Windows that is opening in code instead of English
Usually if it opens in code its because the format its been saved in is not compatible with Word. Look at the last three letters of the document, if they are not .txt or .rtf word does not see it as a valid word file.
Mar 02, 2015 | Microsoft Computers & Internet
My 1990 4runner after putting rebuilt motor in starts but won't stay running. Any ideas?
new engine or starter motor????
stalls. which engine, exactly
all engines have unquick fueling and spark and lots more.
which one? of the 8. (even gas and diesel)
2.0 L 3Y I4
2.2 L 4Y I4
2.4 L 22R-E I4
3.0 L 3VZ-E V6
2.4 L 2L-TE turbodiesel I4
2.4 L 2L-TII turbodiesel I4
2.8 L 3L diesel I4
3.0 L 1KZ-T/TE turbodiesel I4
Dec 28, 2014 | 1990 Toyota 4Runner
How to check the resistance on the iac in a 2000 acura ti?
Here you go: 2000 3.2TL - DTC Troubleshooting: P1519 (14)
DTC P1519: IAC Valve Circuit Malfunction
  1. Reset the PCM.
  2. Turn the ignition switch ON (II).
    Is DTC P1519 indicated? YES -
    Go to step 3.
    NO -
    Intermittent failure, system is OK at this time. Check for poor connections or loose wires at the IAC valve and the PCM.n
  1. Turn the ignition switch OFF.
  2. Disconnect the IAC valve 3P connector.
  3. Turn the ignition switch ON (II).
  1. Measure voltage between IAC valve 3P connector terminal No. 2 and body ground.
    Is there battery voltage? YES -
    Go to step 7.
    NO -
    Repair open in the wire between the IAC valve and the PGM-FI main relay.n
  1. Check for continuity between body ground and IAC valve 3P connector terminal No. 1.
    Is there continuity? YES -
    Go to step 9.
    NO -
    Repair open in the wire between the IAC valve and G101.n
  1. Disconnect PCM connector B (25P).
  1. Check for continuity between body ground and PCM connector terminal B23.
    Repair short in the wire between the IAC valve and the PCM (B23).n
    NO -
    Go to step 11.
  1. Connect IAC valve 3P connector terminal No. 3 to body ground with a jumper wire.
  1. Check for continuity between PCM connector terminal B23 and body ground.
    Go to step 13.
    NO -
    Repair open in the wire between the IAC valve and the PCM (B23).n
  1. Remove the jumper wire from the IAC valve 3P connector, then reconnect the IAC valve 3P connector.
  1. Measure voltage between body ground and PCM connector terminal B23.
    Substitute a known-good PCM and recheck. If the symptom/indication goes away, replace the original PCM.n
    NO -
    Replace the IAC valve.n
May 17, 2014 | 1996 Acura TL Series
Mother board p4msoo-m4
Hello download the manual here:
You need adobe reader, to read content.
Look in the bios setup, for proper boot settings for the drives.
Good luck
Nov 04, 2012 | Biostar P4M80-M4 Socket 478 mATX MB with...
You can find the manual here: The board is usually marked, also, although it is very tough to read the small print.
Oct 31, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
Where is the OBD 2 ECU plug on a 1994 Honda Civic Ex
should be located about 1" from the end of the dash, on the passenger's side. It's a 2P connector, which you jump with a paper clip, and is up under the edge of the dash. The Data Link Connector (3P) and the Service Check Connector (2P) are both housed in a protective rubber mount. Carefully, pry the Service Check Connector free.
Jump the connector, turn the ignition ON, and count the number of long and short flashes, if any, of the Check Engine Light. Yes, you have an OBD-I emission control system. good-day ! 96 on up vehicles are OBD-II,
Mar 31, 2012 | 1994 Honda Civic
Do the rules for playing Scrabble on actual game board with friends specify "no foreign words"?
rules change year to year ,, if your in tournament play, but for the in home player here are the printed rules for the game Acceptable words are the primary entries in some chosen dictionary, and all of their inflected forms. Words that are hyphenated, capitalized (such as proper nouns), or apostrophized are not allowed, unless they also appear as acceptable entries: "Jack" is a proper noun, but the word JACK is acceptable because it has other usages as a common noun (automotive, vexillological, etc.) and verb that are acceptable. Acronyms or abbreviations, other than those that have been regularized (such as AWOL, RADAR, LASER, and SCUBA), are not allowed. Variant spellings, slang or offensive terms, archaic or obsolete terms, and specialized jargon words are allowed if they meet all other criteria for acceptability. Foreign words are not allowed in the English language Scrabble unless they have been incorporated into the English language - for example, the words "patisserie" and "glace".
Aug 10, 2011 | Hasbro Toys
If i am in the process of buying a generator to run 2 carrier RV rooftop ac units how big should the generator be?
You need to find out the maxamps of the rooftops which is located on each unit, then you will need to find out if these are 1phase, 2phase or 3phase units.
That information is also located on the unit and usually is marked 1P or 2P or 3P. If its 3Phase you
would need to talk to a electrical contractor or the
manufactuer of the generator you wish to purchace.
More in for is needed on the phase of the unit and amps that it draws
Feb 12, 2010 | Dometic Rooftop RV Air Conditioner
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
