Question about Dishwashers
What is function of visco plus in dish washing liquid?
3 Suggested Answers
  • 4088 Answers
SOURCE: Dishwasher leaving the remains of dish washing
Is water also standing in the bottom like it isn't getting pumped out? If so, probably the drain system is plugged and everything below the lower spray arm needs to disassembled to the deck--noting the position of each piece as they are removed. Look for food plugging holes in the deck and any obviously damaged parts. Clean the large screen in vinegar and hot water--let soak for a while to remove water and food deposits. Check the drain hose from end to end looking for kinks or other restrictions. Make sure the pump mechanism at the bottom turns freely. Check both spray arms for plugged spray holes or split seams. Reassemble in reverse order. Run a cycle without dishes to clean further--make sure the water drains out at the end. Listen for proper water movement while running. Open the door to inspect progress several times.
Posted on Aug 17, 2009
  • 189 Answers
SOURCE: used dish washing liquid dishwasher damaged?
Hello- NO- Use about 1 gal warm water to: 1- fill bottom of tub. 2- turn on briefly- 5sec - 3- Push Drain button. 4- Press cancel. ---- Repeat. Let me know if this info helps. -ED
Posted on Mar 04, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Visco tv
How do i program my dish network remote ?
Answer The instructions for programming your dish network remote completely depend on the model of your remote. The model of your remote is more than likely located on the back of the remote. You can find more information here:
May 13, 2014 | DISH Network Televison & Video
I have a VISCO 32' tv & lost the remote. Model # VSC-32V1. I need a remote to use to get to the HDMI area. I tried a universal but it only turns it on & does channel.
Check the operation manual and note down the model number and go and fetch it from any electronics shop nearby. These are available freely now in the market.
Jul 19, 2012 | Televison & Video
What is zenamix
Hello. You may visit below link for steps in preparing dishwashing liquid..
ZENAMIX PASTE is a detergent concentrate pre-mix which contains complete anti bacterial ingredients used for dish washing , liquid laundry detergent and other household liquid detergent making it anti stain, anti odor and oil removers, all rolled to one, with a spacial additive of Gentle to Hands (GTU) for hand care, too.
Nov 18, 2011 | Dishwashers
New dishwasher...The Rinse Aid doesn't seem to be putting out any liquid. (How is it supposed to work?) Plus, dishes don't seem to be coming out as clean as expected. In your opinion what is the...
You won't see any liquid it comes out and gets rinsed off during the last wash cycle.As for detergant I think your best bet is to use the tablets. Like the three and one "Finnish " Hope this helps.
Jun 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
White residue baked on dishes and wont come off even when washed by hand
Unfortunately this could be caused by water that is to soft combined with bad wash liquid. Typically you want to make sure you get the highest possible phosphorous content in wash liquid. This will help with the staining on your dishes. At this point you won't be able to get it off the dishes.
Dec 23, 2010 | Whirlpool 24 in. DU915PWP Built-in...
The dishwashing liquid has gotten thick in my ge dishwasher. The dishes are not getting clean. How do I clean out the dishwashing liquid resevoir?
Try running the hottest, longest programme WITH detergent but WITHOUT dishes. If you usually wash just a few dishes on a short programme, you might find that the machine never gets hot enough to wash away all the detergent residue.
Oct 09, 2010 | GE Dishwashers
Chalky residue left on dishes
The chalky residue would have formed due to the washing liquid or powder used. According to my experience, I am happy with "Amway -Dishwasher liquid".Please try it for washing your dishes. It leaves no residues and even cleans your dishwasher. On continuous usage, you may find the difference. Overall, it cleans your dishes as well as washer simultaneously. Though its a bit expensive, it is worth buying it.
please search in "ebay" for your country to get the product. Please rate my solution as helpful. Regards, Venu.
Feb 18, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Miele W1119 not cleaning white clothes properly
liquid detergent is a pain and not as good as powder. liquid detergent often makes machine smell as well i doubt there is a fault with the machine. try putting on a boil wash with no clothes and this will clear out the slime left behind by the liquid detergent. you didn't say what colour the stains are but iy grey or brown it could be from your water supply - a more common problem than you might think. turn off water and remove the supply hose. there should be a gauze filter at one end and make sure not clogged with dirt. also look into the spigot of the vavle and see if any muck there.
May 11, 2007 | Miele Touchtronic W1119 Large Capacity...
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
