Connect mediacom cable to my apex...all the cables are hooked up correctly but it just says no signal.
What is the mediacom connected to? If the antenna connector, (usually screw-on type F) then set it to TV. Does Mediacom need to have a box between the cable and the TV? Sometimes cable systems do not use standard television signals, and a box is required to display on a TV.
If mediacom has a box, and cables are connected to (commonly red, white, and yellow) RCA connectors, then AV 1 or 2, depending on which connectors you plugged them into on the TV.
