Connecting sky box to television - Televison & Video
4 Suggested Answers
SOURCE: Sky + box and Akura 37'' television
with your tv swiched on, Turn your sky box off then keep your finger on the backup button whilst turning your box back on, make sure you keep your finger on backup button until all the lights come on on the front of your sky box, or a message comes on screen (tv) saying "UPDATING SYSTEM SOFTWARE, DO NOT DISCONNECT FROM THE MAINS, THIS WILL TAKE APPROX 10 MINS"
if this does not help give me a bell on 07738910264 after 330pm mon-fri
Posted on Nov 13, 2008
SOURCE: i cannot get my video connected to my toshiba regza television
If there is two scart sockets on the vcr,make sure you are in the one marked av1.
Posted on Nov 18, 2009
BElectric
  • 1140 Answers
SOURCE: I have a Tosumi television connected to standard
Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
Hope this helps.
Posted on Oct 21, 2010
Testimonial: "thanks for effort. will try when i get home"
I don't have an aerial, I have satellite. I hav gone through the tuning several times and called the help desk: no joy. I have connected: Scart Sky box-TV....HDMI sky box-TV
The sky box is the box you use to watch TV The flat panel is just the monitor to receive the picture from the sky box you cannot tune the TV to receive the sky EPG signal Use the HDMI input in the TV menu that the sky box is attached to
Feb 22, 2016 | Televison & Video
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
Mar 13, 2015 | Televison & Video
Sky decoder connection diagram
Which sky box do you have, This is the diagram for a Sky+HD Box:
http://prod-help-sky-com.s3.amazonaws.com/uploads/TV_SetUpBox_ConnectCables_L.jpg
Oct 22, 2013 | Sony Televison & Video
How do I connect my Toshiba SD5010KB thru my Sky Box.
HDMI Tv's have a HDMI input and connect that the to the HDMI input on back of HD Sky box if not HD ready TV you'll have either 1 or 2 F-Connectors which go from Dish to input points1 and 2 on the back of the sky box then Scart lead from box to TV -
May 22, 2011 | Televison & Video
I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
Hope this helps.
Oct 21, 2010 | Televison & Video
LE40R74BDX HDMI input stopped working
I work for sky as an engineer (not a subby)
HDCP is the encryption that is sent down when a program is transmitted. I have had this several times over the years and have found out that you need go to the manufactors web site or call them to update your telly this will sort out this problem.
I would do this sooner then later... reason I am telly you this is sky have take the Component inputs off all the sky boxes now.... The box you have is a THOMSON (have a look.... make you smile)lol this was due to people connecting there sky HD box to there pc via Component and using programs like Copy+ and extract + to copy the content.
If your box breaks down. then you are snookered if you telly is not going to accept the skyHD through a HDMI connection.
Hope this helps
Cheers
Little Dish Fitter
Mar 04, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Nov 11, 2008 | Televison & Video
Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Jan 18, 2008 | Televison & Video
Rf2 outlet from sky hd box
on your sky remote
services
0 1 select
make sure the rf is set to on
Remember the channel rf number,
go to your television the link is to.
go to menu then setup and then manual tune
select the channel you want to view sky on. normally channel 6 on your analogue
then go to Channel type in whatever the rf setting was on your main sky box then press save.
that is your telly sorted out. if you have a magic eye connected at the link end you should see a red led light lit up.
if not remove the magic eye and connect it straight into the back of your sky box RF2
just to make sure that the eye is not at fault.
hope this helps
ill check in a day or two to see if you need more help.
Cheers
Little Dish Fitter
Nov 14, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
