Question about Dehumidifiers
Dehumidifier float switch and black strip
Frigidaire dehumidifier manual says before first use, "make sure the float switch is properly set." Where is it, what does it look like, how to check? (Manual explains no further.) ALSO: There was a small thin black (plastic?) strip in the bucket. When I emptied the bucket, the strip went down the drain. What was it, and is it OK that it's gone?
SOURCE: Drain problem
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
Posted on Jul 18, 2007
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
  • 5184 Answers
SOURCE: Are you supposed to put water in the bucket of the
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
Posted on Aug 10, 2009
gemyr2
  • 63 Answers
SOURCE: My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Posted on Feb 25, 2011
Frigidaire FDL50s1 runs continuously but will not collect water. What could be the problem & can it be fixed?
Thank you for your post, K!
I understand that your Frigidaire dehumidifier is continuously running and it is not collecting water. This can be caused by a dirty filter. A dirty filter can restrict air flow which will allow your dehumidifier to not pull in air. I would recommend checking your filter to make sure it is clean.
Frost on the coils within your dehumidifier will also cause your dehumidifier to stop working as well. You should check to make sure that there is not frost visible on your dehumidifier. If you do locate frost you would need to perform a manual defrost on your dehumidifier and you can do that by disconnecting power from it for at least two to three hours.
If these steps do not resolve your issue you may need to reach out to the manufacturer for a proper resolution. I hope this information is helpful to you. -Matt
Jun 13, 2015 | Frigidaire Dehumidifiers
Bucket full showing
Hello Friend, thank you for allowing me to assist you!
Once the "BUCKET FULL" illuminate on your Frigidaire dehumidifier, soon after your appliance will shut down. Then you may remove the bucket by pressing the sides gently to unclip it and empty the collected water. After you reinstall the bucket, the float switch will reset. Hope this helps! - Z
Jul 17, 2014 | Frigidaire 50 Pint Capacity Dehumidifier
I thought the styrofoam inside the dehumidifier float was packing material & threw it away. Now my dehumidifier gets too full before the "full" sensor comes on. Can I replace the styrofoam?
Hi Kim - I understand that you removed the styrofoam inside the dehumidifier float thinking it was packing material, however I would recommend contacting the manufacturer to verify if it the part is available and can be replaced.
Sep 05, 2012 | Frigidaire FDL50R1 Dehumidifier
"Check drain" light is on
If the float switch is indicating a full drain pan, the light will be on and the compressor and fan will not run. Make sure the dehumidifier is installed level and the condensate drain is open allowing the drain pan to empty. Next check that the float is free to move up and down and the switch operates a required. Call the manufacturer at 1-800-533-7533 for parts and instructions if there is a problem wirh the float switch.
Aug 06, 2011 | Therma-Stor Santa Fe Compact Dehumidifier...
Unit wont run but lights up. It reads low humidity even though its high
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | Haier HD656E Dehumidifier
Light saying bucket is full is on all the time and unit is not working
Good luck.
Jul 28, 2010 | Kenmore 54501 Dehumidifier
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
My Fedders dehumidifier keeps reading full all the time
When you move the float up to enage the switch does it shut it off? If not you may need to adjust it
Jun 19, 2009 | Maytag M3DH30B2A Dehumidifier
Kenmore Dehumidifier Model 580.52650 Says "Bucket Full" - Wrong
the problem is with the switch which is connected to the float arm, try pulling it manually, it shoud turn on and off your unit if working properly
Jun 14, 2009 | Kenmore 54501 Dehumidifier
Danby dehumidifiers
Try manually work the float and switch the float controls to make sure it is not hung up. You may need a new switch if that does not work.
Dec 31, 2008 | Danby DDR6588EE Dehumidifier
Dehumidifiers Logo
89 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
