Question about Dishwashers
Why we need visco plus in making dish washing liquid?
4 Suggested Answers
  • 4088 Answers
SOURCE: Dishwasher leaving the remains of dish washing
Is water also standing in the bottom like it isn't getting pumped out? If so, probably the drain system is plugged and everything below the lower spray arm needs to disassembled to the deck--noting the position of each piece as they are removed. Look for food plugging holes in the deck and any obviously damaged parts. Clean the large screen in vinegar and hot water--let soak for a while to remove water and food deposits. Check the drain hose from end to end looking for kinks or other restrictions. Make sure the pump mechanism at the bottom turns freely. Check both spray arms for plugged spray holes or split seams. Reassemble in reverse order. Run a cycle without dishes to clean further--make sure the water drains out at the end. Listen for proper water movement while running. Open the door to inspect progress several times.
Posted on Aug 17, 2009
  • 189 Answers
SOURCE: used dish washing liquid dishwasher damaged?
Hello- NO- Use about 1 gal warm water to: 1- fill bottom of tub. 2- turn on briefly- 5sec - 3- Push Drain button. 4- Press cancel. ---- Repeat. Let me know if this info helps. -ED
Posted on Mar 04, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Posted on Apr 18, 2010
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
Visco tv
How do i program my dish network remote ?
Answer The instructions for programming your dish network remote completely depend on the model of your remote. The model of your remote is more than likely located on the back of the remote. You can find more information here:http://tech.dishnetwork.com/departmental...
May 13, 2014 | DISH Network Televison & Video
What is zenamix
Hello. You may visit below link for steps in preparing dishwashing liquid..
http://qousay.hubpages.com/hub/How-To-Make-Dish-washing-Liquid
ZENAMIX PASTE is a detergent concentrate pre-mix which contains complete anti bacterial ingredients used for dish washing , liquid laundry detergent and other household liquid detergent making it anti stain, anti odor and oil removers, all rolled to one, with a spacial additive of Gentle to Hands (GTU) for hand care, too.
Nov 18, 2011 | Dishwashers
New dishwasher...The Rinse Aid doesn't seem to be putting out any liquid. (How is it supposed to work?) Plus, dishes don't seem to be coming out as clean as expected. In your opinion what is the...
You won't see any liquid it comes out and gets rinsed off during the last wash cycle.As for detergant I think your best bet is to use the tablets. Like the three and one "Finnish " Hope this helps.
Jun 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
White residue baked on dishes and wont come off even when washed by hand
Unfortunately this could be caused by water that is to soft combined with bad wash liquid. Typically you want to make sure you get the highest possible phosphorous content in wash liquid. This will help with the staining on your dishes. At this point you won't be able to get it off the dishes.
Dec 23, 2010 | Whirlpool 24 in. DU915PWP Built-in...
The dishwashing liquid has gotten thick in my ge dishwasher. The dishes are not getting clean. How do I clean out the dishwashing liquid resevoir?
Try running the hottest, longest programme WITH detergent but WITHOUT dishes. If you usually wash just a few dishes on a short programme, you might find that the machine never gets hot enough to wash away all the detergent residue.
Oct 09, 2010 | GE Dishwashers
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The dishes come out dirtier after they're "washed"! The soap leaves a filmy residue and I have to re-wash all the dishes. I've tried liquid Cascade, the Finish tablets, and putting Jet Dry rinse aid in...
Take out the botton dish rack and check the drain. Most likely there is a screen that is supposed to catch big debris and keep it from entering the drain. It's probably got a lot of gunck in it. Take the screen out and clean it and check under the screen too!
Jul 29, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Soap foam left after dishes are washes. can't dry properly. and always has soapy water left in it and on the washed plates.
Try adding some liquid fabric softener to your dishwasher. This will reduce the foaming. Also make sure there is rinse agent in the proper dispenser, this will reduce the soap sticking to the dishes. Finally, reduce the amount of dishwasher powder or liquid you put in for each wash. If water remains in the bottom of the dishwasher, check if there is a filter or drain hose clogged. Is the dishwasher drain hose connected an undersink garbage disposer? If yes, make sure it is run periodically so it does not clog up.
Aug 09, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
