Question about ROOTS Watches
I would like a new watchband for a roots athletics RY2114 evidence.just a band.
escapement
  • 2334 Answers
SOURCE: Where can I get a new band for my LaCrosse Radio Controlled Watch
Follow this link and choose whatever you want:
http://www.google.com/search?ie=UTF-8&oe=UTF-8&sourceid=navclient&gfns=1&q=watch+bands+online
Rate me, please.
Posted on Mar 20, 2009
SOURCE: Buy and replace new watch band ?
I just replaced the band on a women's ironman watch, so I know it is tricky, but can be done. First remove the old band using a small flat blade screwdriver and determine that the spring bars that came with the new band are the right size by comparing with the old ones. My new ones were too large. Then, use a pen to make marks on the back of the watch case in alignment with the spring pin holes . Put a spring pin into the band and position the band on the watch the way it will be attached, with the pin just above the marks. Use the small flat blade screwdriver to insert one of the spring bars into its hole and align the other side of the spring bar with its mark on the case. Compress the spring bar and slide it down until it roughly aligns with its hole, then, push the band sideways toward the hole and wiggle the band until the pin seats. Apparently the hole alignment is very tight and, without that last step, the pin simply will not seat. After spending a lot of time with the first strap, locating the spring pin hole by trial and error, I used a magnifying light for the second strap to allow me to see the spring bar hole, making the process a lot faster.
Posted on Apr 26, 2009
Fixe_You
  • 1800 Answers
SOURCE: how do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Posted on Jun 20, 2009
    mcdevito75
    • 1970 Answers
    SOURCE: I need to replace the watchband.
    mcdevito75 here, Best Bet, Look for a small watch reoair shop in your area for the strap and instalation.
    Posted on Jul 27, 2010
    SOURCE: Looking for (2) links for Charriol Columbus
    i need a new charriol bracelet for a columbus model- white mother of pearl, with diamonds in a rectangular case.
    I would like to purchase a brand new bracelet for this model how can you help me ?
    Thanks,
    Posted on Sep 13, 2011
    Need the replacement strap for Timex watch M805
    Timex Watchband - watchbands.com
    www.watchbands.com/Departments/Timex-Watchbands.aspx
    Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
    Jan 01, 2016 | Timex Watches
    Need replacement part for end of watch band Michael kors mk5362
    Forget it! Unless you have a specialized jeweler nearby who stocks watchband parts you would be better off getting a new watchband!
    Jan 07, 2013 | Watches
    The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
    You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
    Sep 21, 2011 | Watches
    Looking for a replacement watch band for SEIKO SPORTURA HONDA F1 RUBBER BAND/STRAP SNA749P1 Where can I get one and what is the best price for customer in UK?
    I've been looking for a replacement for the Seiko SNAE93p1 and have seen the replacement for this in several places. I only remember because it has a red and black band similar to the one on the watch I'm wanting, and I figure that I should get a replacement band when I buy this new watch, as the synthetic bands on Seiko watches tend to break after about 3 years or so.
    Watchbands.com has it for $65 I believe. watchbands com
    Jul 20, 2011 | Seiko Sportura BAR Honda Racing F1...
    How do i change watchband for casio bg169wh
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
    Pin on the watchband is protruding
    No need to buy a new watchband friend, you need a new pin. The spring inside the pin has lost its elasticity ... you won't spend a fortune ....
    Please rate the resolution.
    Mar 18, 2009 | Casio Pathfinder PAG60-1AV Watch
    Athletic works watch
    I just bought an Athletic Works watch at WalMart that is identical to the Aquatech watch I bought there some years ago. My band got hard and cracked so I needed to buy a new one as the band is not available. For $9 the entire watch is probably cheaper than a band. I used the instructions from my Aquatech to set the stuff on the AW. I found the instructions on the internet. Here is one site that has them.
    http://www.ehow.com/how_4587869_set-aquatech-watch.html
    Give it a try.
    Clem S
    Sep 23, 2008 | Watches
    Watches Logo
    77 people viewed this question
    Top ROOTS Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a ROOTS Watch Expert? Answer questions, earn points and help others
