Question about Ludwig Music
Have a Ludwig Kenmore Banjo
4 strings 22 frets, looking for serial number all i can find is Patent Pend 14428 Any Ideas???
  • 6 Answers
SOURCE: strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Posted on Nov 15, 2008
  • 4234 Answers
SOURCE: Own Peavey Cirrus 5 BXP , Strings are to close to the frets.
If the problem you are having is buzzzing, yes. This height is called the "action" of the bass. You can change either or both the saddle and bridge. I would recommend that you have this examined at a music store to verify that the neck is straight and does not need adjustment too. This is part of normal upkeep for these. Expect an overhaul cost of about $50 if you have it adjusted.
Dan
Posted on Mar 19, 2009
1fastbob
  • 301 Answers
SOURCE: truss rods and dead frets
I own an Epiphone Casino and if I needed to adjust the truss rod I would take it to a luthier (stinged instrument repair person). There is a good write up on it here. http://www.fretnotguitarrepair.com/trussrods.htm
Hope this helps.
Bob
Posted on Oct 31, 2009
  • 4 Answers
SOURCE: buzzing of strings in frets up to fifth fret
For your buzzing problem you could try bowing the neck to see if that helps.
Posted on Apr 08, 2010
Testimonial: "I don't know how to adjust the neck so I'm leaving it up to a pro, but I think this is exactly what needs to be done. Thanks for the imput"
  • 57 Answers
SOURCE: buzz at the e6 string 11th fret
Have you changed strings on it? Old strings get worn spots in them from rubbing on the frets that will cause these type of symptoms. If you put new strings on and get the same issue, check your neck relief (the amount of bow in the neck) to do this, hold your low E string at the first fret, and at the 12th or 14th fret. The neck should have a slight bow in the middle that puts it between 1/16" and 1/8" or so away from your string. If it does not have enough bow in it, you can adjust the truss rod. Most guitars use an allen wrench for this, it will be inside the soundhole on an acoustic usually, and on an electric it is normally on the headstock under a cover. There are many how-to's online about adjusting a truss rod, the key is to do it very slowly, only do about a 1/2 turn a day, retune, check it again the next day. Loosen the truss rod to put more neck relief, tighten to straighten the neck. If this still doesn't fix you up, let me know, and I'll tell you where to go from there.
Posted on Apr 24, 2010
Tune Guitar strings 1,2 & 3 to Banjo and play with finger pickers. Bass strings to accompany. Developed complicated chords (Including Bass strings) I need to record this on paper - any tips?
Are you familiar with Tablature notation. It's instrument specific and instead od a regular staff you maje a duagram od the instruments strings looking down on the neck and then instead of notes the number of the fret goes on the relevant 'string'
https://www.guitartricks.com/helptab.php
and it's similar for banjo. Google tablature explained and a page comes up with a selection of instrument tabs.
Sep 15, 2017 | Bass Music
I would like to find out the model name and the value with just the serial number and a picture
The best source og info would be to talk to dean customer service directly. Here's their link-
Contact Us Dean Guitars
Mar 10, 2016 | Bass Music
Would like a parts schematic for a Bb400 gold tone bass banjo
This is a list of All the parts you need, I don't know about a schematic?
1 Maple Neck ? 1 11" wood rim ? 1 11" notched tension hoop ? 1 Flat head alloy tone ring (Optional bell brass available) ? 1 Resonator (not included in the open back kit) ? 1 11" Remo frosted banjo head ? 1 Arm Rest ? 2 Coordinator rods with hanger bolts (one longer than the other) ? 1 "L" shaped tailpiece bracket (may be attached to coordinator rods) ? 1 5th string nut ? 4 Guitar style tuners (planetary tuners optional) ? 1 Geared 5th string tuning machines ? 24 Shoe style lugs with bolts and washers ? 24 Hooks and nuts ? 1 Nut, pre notched ? 4 Resonator plates ? 4 Brass inserts (brass anchors that are threaded on the inside) ? 4 Resonator bolts (knurled on the outside with a Phillips screwdriver receiver on top) ? 1 5 string bridge ? 1 Gary Price style Tailpiece ? 1 Set of strings ? 22 Pre-cut (ready to install) frets ? 1 Truss rod cover (including three screws)
Mar 06, 2015 | Bass Music
Banjo tuning and bridge placement
Assuming it's a 5 string banjo, the notes are low to high G(octave)DBGD. The bridge is placed by hitting the harmonic over the twelvth fret and then fretting that note. Move the bridge until those two notes are the same pitch. Generally the bridge ends up closer to the tailpiece than the middle.
Aug 20, 2014 | Epiphone Music
I bought a used Fender FB55 banjo, it's appearance looks new. I'm new to banjo's but not guitars. I really didn't know how a banjo should sound. I practiced with it as is, I noticed that I...
Check the neck to body attachment. There may be a problem there, especially if it has been strained in the past. The fact that the strings were so high when you got this would indicate there MAY be a problem with the neck attachment or the body where it attaches. Word of caution: Investigate how repairs are done on the instrument before attempting a fix. Using wrong materials can permanently disable an instrument. Banjos DO go out of tune easily, depending on how they are played. Another thing to remember is that strings are within about 10% of breaking when in tune on stringed instruments.
Sep 10, 2011 | Fender FB55 5-String Banjo (Refurbished)
The problem I have with my music man bongo bass 4 strings,,, is that the string 4 at fret 5 sounds very strange as making waves, but it sounds good with the other tones, on the other strings when I play...
Check first it is not hitting or touching the next few frets, in case they are high. Or maybe the 5th fret is low. You could raise the action and/or adjust the neck relief to test this.
If it is not a fret problem, it may be a real dead spot on your bass. If so, it would be regardless of the pickup used and could be heard acoustically if you could hear notes that low easily. Most guitars have notes on the fretboard somwhere that are a little dead. It is due to destructive interference and there is not much that can be done. To happen at the 5th fret is unusual though. Make sure the string is wound properly around the head, and that nothing is loose and actually moving/buzzing when you play the note.
Other causes can be a loose fret, loose bridge parts or a loose neck joint.
Mar 07, 2011 | Music Man Bongo 4-String Bass with 2...
Music Logo
24 people viewed this question
Top Ludwig Music Experts
Michial Gueffroy
Are you a Ludwig Music Expert? Answer questions, earn points and help others
