Question about The Computers & Internet
How do i skip the verifying photo gesture - The Computers & Internet
When sewing it skips stitches also the thread keeps breaking.
Remove the thread from the machine.
Install a brand new needle.
RAISE the presser foot and rethread the top thread.
Verify the thread path is correct.
Load and thread the bobbin case & install it. Verify it is correct.
Set the top tension at the midway point.
Re-test your stitch.
Sewing Machine Problem 1 Thread Breakage
10 reasons for skipped stitches
Mar 22, 2017 | Sewing Machines
How do I get back a full screen instead of having 2 different screen open
Try with enabled gestures in general settings:
In apps where you can navigate from side to side, such as Photos or iBooks, you need to use the swipe.Using one finger, lightly run your finger across the screen from one side to the other and you can navigate from page to page in one simple motion. get-back-full-screen-instead-having-2-u3wnnnxjlb3ct0ebur4t0xqn-1-0.jpg
How to use Gestures on iPad iPhone iOS
Sep 28, 2014 | Apple iPad Tablets & eReaders
How to turn off Htc Media link
Settings > Display, gesures & buttons > Gestures > uncheck gestures smile.gif
This will disable this three-finger-gesture.
Sep 13, 2013 | Computers & Internet
Touchpad on panasonic cf-52
You're going to need the drivers for the gestures installed, you can find this on their website under support and drivers.
It's pretty much the driver for the touch pad, then you can enable gestures by opening the GUI on for the program and enabling "gestures"
Feb 24, 2013 | Panasonic Toughbook CF-51 Notebook
What is multi gesture
Multi-Gesture just means there are gestures you can do with the touch pad that will do certain things, like zoom in on the page or scroll up and down.
Aug 24, 2011 | Acer Aspire One PC Notebook
I need instructions on how to reinstall my sound device, I have no sound comeing out of my speaker and it is hooked up and turned on
  1. Bad software settings.
  2. Corrupt or missing sound drivers.
  3. Compatibility issues with the operating system and/or other hardware.
  4. Speaker related issues.
  5. Bad or missing sound card.
Windows XP
  1. Open the Control panel
  2. Open the "Sounds and Audio Devices" icon.
  3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
  4. If you were able to check this box, click ok and close out of this window and the Control Panel.
  5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
  1. Open the Windows Device Manager
  2. Verify there are no conflicts or errors listed anywhere in Device Manager. If conflicts exist skip down to conflicts section.
  3. Verify no other devices are listed. If other devices are listed skip down to other devices section.
  4. Verify that your "Sound, video and game controllers" category is listed, if not skip down to the missing sound card section.
  5. If no conflicts or other devices are listed and your sound card is listed with no conflicts, skip to the next section.
If you are unable to locate additional information about your issue or are unable to resolve the issue, follow the below steps.
  1. Under Sound, Video and game controllers highlight each device and press the delete key to remove the device.
  2. Reboot the computer.
  3. As the computer is booting the system will detect the sound card and any of it's devices and re-install those devices. If prompted for a location of drivers, try pointing it to your sound card CD and/or your Windows CD. If this does not work or is unable to locate the proper files, you will need to get the latest sound drivers from your sound card manufacturer.
Feb 24, 2010 | Dell Dimension 2400 PC Desktop
My sound will not work on dell d360 with XP. I
Verify the installed driver settings
If you are missing the "Sound, video and game controllers" category in Device Manager, it is likely that the sound card drivers are not installed properly, sound card has been disabled, sound card is bad, or no sound card is available in the computer. First, verify no conflicts or other devices are present in the Device Manager; if these are present it is likely they are the sound card and/or devices causing the sound card not to be detected. Second, verify that the computer has a sound card and/or that the sound card is enabled on the computer.
Feb 24, 2010 | Dell Latitude D600 Notebook
I can't kill the zoom feature on my Acer Laptop. It is a pain.
Go to Control Panel > Mouse > Device Settings > Settings > Advanced Gestures > Pinch
(or alternatively right-click the Synaptics Pointing Device icon in your taskbar and select Pointing Device Properties)
Untick the box that says 'Enable Pinch'. This will disable the zooming.
Additionally, you might be suffering the same problem as I was which was I had no idea how to use the zoom and that's why I wanted to lock it. Having Google stuck on too-big-to-navigate-properly or too-small-to-read for days at a time prompted me to learn. I've since decided the zoom is useful and I'm keeping the feature enabled.
Here is what Synaptics have to say about the 'pinch' gesture:
The Pinch gesture delivers zooming functionality in many applications. The Pinch gesture can be used to perform the same function as a scroll wheel on standard Windows applications that support CTRL-SCROLL WHEEL zoom functionality.
To perform a pinch gesture, place two fingers on the TouchPad surface. Move them closer together or further apart. To zoom in, place your fingers on the TouchPad surface near to each other and then slide them apart. To zoom out, begin by placing your fingers apart and then moving them closer together.
The best zooming experience results when the finger tips of the two fingers are used for the gesture.
That will hopefully be of assistance if you want to learn how to use the zoom rather than disable it. It took some practice but I can do it now without a problem so can fix windows when I accidentally zoom on them.
Aug 03, 2009 | Acer Aspire One PC Notebook
Aspire one ZG5 CCHANGES THE ZOOM LEVEL ON ITS OWN
Additionally, you might be suffering the same problem as I was which was I had no idea how to use the zoom and that's why I wanted to lock it. Once I learned, I've decided the zoom is useful and I'm keeping the feature enabled.
Jun 04, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
48 people viewed this question
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
