Question about Dishwashers
I Have code OE come up with the Dishwasher starts beeping
2 Suggested Answers
SOURCE: oe code on LG dishwasher following garbage disposal replacement
Well, there is the plastic block in the garbage disposal where the drain hose goes on (as not every disposal will be attached to a dishwasher). Punch this out with a screwdriver, fish the plastic plug out with your hand and reattach the hose. You are good to go.
Posted on Dec 01, 2008
Error code oE
According to page 25 of the users guide you can download from Samsung's web site at http://www.samsung.com/us/support/owners/product/DMR57LFS oE means, "Water level error (over-level)"
Jan 20, 2013 | Samsung DMR57LFS Stainless Steel Builtin...
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Error code 0E
OE is OUTLET ERROR.
More often than not, a blockage is in the pump(not that easy to get to and quite a long step by step process)
You might also find the blockage at the end of the drain hose, where it connects to the drain pipe- remove the hose clamp and inspect hose and spigot.
May 04, 2010 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Oe code on LG dishwasher following garbage disposal replacement
Hi. I just had the same trouble. Your garbage disposal comment there gave me an idea. The drain hose from your dishwasher likely goes to the garbage disposal and then out the drain. My hose had a little blockage at the joint where the hose goes into the disposal. I was able to clear it just by giving it a wiggle....all is well now.
Good luck.
Sep 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
OE blinking
Hi
I have the same machine and OE means drainage trouble.
  • Check clogging of water drain hose (or hose twist of freezing)
Cheers
Aug 01, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
Owen Barnes
