Question about Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 680 Touch Screen not working
The touch screen works sometimes but it not calibrated so even when it does work it doesn't. It has not been dropped or damaged, however the owner of the Nuvi just updated it and down loaded new firmware so I think this could be the issue but we hooked it back up to the pc and installed the old firmware still didnt work so we up dated it again. Still nothing. Also been having problems with the mount power cable not staying plugged in. So its not charging properly. I called Garmin which I advise agaisnt the wait was 40 min. They told me I would have to send it in they would replace the screen for 125$
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Please see this link.... it can be replaced for far less than a new unit:http://www.sharc.net/gps_LCD_repair.htm - Jim
    Brigadier General:
  • 4,090 Answers
You dont have much option, if the touch screen failos or becomes intermittent then its dying or dead and can only be fixed by a total replacement
Cheaper to buy another GPS
Posted on Jul 25, 2009
I have a Garmin Nuvi 1450 that I bough in December 2010. This morning, when i try to type in an address, the touch screen is behaving erratic. For example, when N is pressed, it types M. Erase is not...
nuvis do not have a calibration screens or settings, to fix your issue try updating the units firmware with Garmins WebUpdater software this could fix your issue, it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 13, 2011 | Garmin nuvi 1450 GPS Receiver
I am looking for a repair manual.. Does anyone have one in digital format?? 2.5 yo Nuvi 680 na touch screen stoped working. matbe a bad connecton.. I cant get it open there are only 2 screws I can see...
If the Touch Screen isnt working, have you tried to recalibrate the screen?
Turn off the Nuvi and then back on.
Slide Power key to the right (lock )
Hold your finger on the screen for about 30 seconds untilthe calibration screen appears.
Follow the on-screen instructions...
Also the 2 screws you took off once you done that you would have to use a plastic pry tool to lift cover up
Oct 26, 2010 | Garmin Nuvi 680 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen on my garmin nuvi 205 stopped responding
If the touch screen is not working properly, calibrate the touch screen.
Turn Nuvi off and then back on.
Slide power key to the right (lock). Hold your finger on the screen for about 30 seconds until the calibration screen appears.
Follow the directions on screen instructions
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
Touch screen not responsive. LCD screen OK.
Try to calibrate the touch screen .
If not send it to a repair centre they will fix the touch screen for you.
Try here www.satnavrepairservice.com
Regards
Jul 18, 2009 | Garmin Nuvi 680 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
3,049 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
