Question about Konica Minolta Office Equipment & Supplies
No drum replace & developed replace how to sole konica minolta bizhub 206 error code m2 reset
  • Konica Minolta Master
  • 6,161 Answers
Did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
Posted on May 06, 2017
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
kraggarwal_k
  • 6 Answers
SOURCE: What is m2 code how cani reset in Konica Minolta
This is to display the count of the supplies life counter.
When the counter is reached to 0 life 1 will be detected and maintenance call M2 will be appeared.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
- To clear the count, use [CLEAR DATA] of the Service Mode.
Posted on Nov 20, 2014
  • 106 Answers
SOURCE: konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
Posted on Dec 22, 2014
  • 34170 Answers
SOURCE: Caution Maintenance CAll M2 Call Service Konica Minolta bizhub 185
Call for service
Posted on Oct 25, 2016
Konica minolta bizhub 206 maintainance service m2 how to set this problem
Apr 23, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
replace the drum and developer and then reset the counter
How to reset m2 error
Have you replace the developer and the drum. First clear the counters for the drum and developer and then replace the drum and developer, then run the required F8. if not the machine will start showing bad copies showing codes. If you clear the counters and don't do anything then the copier will think the parts are new set voltages as required when in fact they are old and will cause problems. So recommend you do the right thing get a tech out to replace the drum and developer
May 19, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica mintola bizhub 164 maintainace call (M2)
replace the drum and developer and clear the counter also ensure you run the F8 after developer been replaced and new drum are installed
Mar 25, 2014 | Konica Minolta Office Equipment & Supplies
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
Konica Minolta bizhub 210 error m2 appear on display
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
