My drum is genuen but bizhub206 is show m2 error code how to reset this
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
Mintenance call m2
M2 means Time to replace your consumables (drum,developer,cleaning blade,drum charge assy & cleaning pad) after replacement reset it to Tech rep mode.
Oct 28, 2014 | Konica Minolta Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
BIZHUB 164 error M2 what have I to do
replace the drum and developer and then reset the counter
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
How to reset m2 error
Have you replace the developer and the drum. First clear the counters for the drum and developer and then replace the drum and developer, then run the required F8. if not the machine will start showing bad copies showing codes. If you clear the counters and don't do anything then the copier will think the parts are new set voltages as required when in fact they are old and will cause problems. So recommend you do the right thing get a tech out to replace the drum and developer
May 19, 2014 | Konica Minolta bizhub C250 All-In-One...
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
Konica Minolta bizhub 210 error m2 appear on display
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
Code m2
M2 is a maintenance code, it is usually tied to one of the machines consumable products, drum, developer, or fuser rollers. These items should be checked before attempting to reset the code.
Hope this helps.
May 11, 2009 | Konica Minolta DiALTA CF910 Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
22 people viewed this question
