Question about whipper snipper stihl fs 38
Please give me the correct part no for still fs38 around 7years old..
The ignition module part No. is 4140 400 1303A. for the fs 38. the ignition. module Part no 4140 400 1308 does not fire at the same as 4140 400 1303A resulting in incorrect timing Please. Please supply correct part No. for my fs 38.
What is the gap on the coil on a sthil fs38
back firing most likely caused by the flywheel key being partially sheared. air gap for coil should be around .010
Jul 19, 2016 | whipper snipper stihl fs 38
What is the gap on the coil in a sthil fs38 weed wacker
W H a c k e r not wacker
wack
wak/ USinformal
adjective
adjective: wack
1.bad; inferior.
"a wack radio station"noun
noun: wack; plural noun: wacks
1.a crazy or eccentric person.2.worthless or stuupid ideas, work, or talk; rubbish.
"this track is a load of wack"Origin
1930s: probably a back-formation from wacky.
whack
(h)wak/ informal
verb
verb: whack; 3rd person present: whacks; past tense: whacked; past participle: whacked; gerund or present participle: whacking
1.strike forcefully with a sharp blow.
"his attacker whacked him on the head"North Americanmurder.
"he was whacked while sitting in his car"noun
noun: whack; plural noun: whacks
1.a sharp or resounding blow.2.a try or attempt.
"we decided to take a whack at spotting the decade's trends"3.British
a specified share of or contribution to something.
"motorists pay a fair whack for the use of the roads through taxes"Origin English thwack
How to Install a new ignition coil FS 38
a business card will work to get a workable gap but the exact distance is 0.15 - 0.45 mm
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 12, 2014 | whipper snipper stihl fs 38
Sthil fs 38 grass trimmer will not start
does it have spark, compression and fuel.? more info please
Jul 08, 2014 | whipper snipper stihl fs 38
REPLACE TRIGGER IN STIHL FS 38
Heres the illustrated parts diagram showing the beakdown on the handle and location of the trigger mechanism. If you want the full parts manual, i can send it to you. :)
Apr 20, 2013 | Stihl Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
My husky1850 generator has no spark used once, 1yr old.,
Hi ikeano29...
Remove (if necessary) and check your flywheel where the magnet is at for rust,corrosion, and lightly sand with fine sandpaper to clean the surface, then sand the face of the induction/ignition module to also give it a good conductive surface.
Reinstall the flywheel again, if still no spark...then replace the induction/ignition module as it is faulty.
Note: Be sure to measure the distance between the module and the flywheel to make sure you put the new module in at the correct distance from the fly wheel or you will get no spark also.
Please take time to rate me
Aug 29, 2011 | Garden
I am working on a 1989 Olds Cutlass Supreme International with a 2.8L V-6. It sat for about a year and when I got it I tightened the negative battery cable and it fired right up. It ran for about 5 hours...
Try having the ignition module checked. The ignition module is located underneath of the coil packs. Usually Auto Zone or Advance Auto Parts can test them. Another possibility is low fuel pressure. There is a schrader valve on the fuel inlet line that you can hook up a fuel pressure tester to. The pressure should be around 38 PSI.
Nov 30, 2010 | 1989 Oldsmobile Cutlass Supreme
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
Sep 06, 2010 | Oregon Scientific Complete Carburetor for...
Garden Logo
66 people viewed this question
Top whipper snipper Garden Experts
John Mayer
John Mayer
Level 1 Expert
richie46
ray gallant
Are you a whipper snipper Garden Expert? Answer questions, earn points and help others
