Cant get the tv to show HDMI3 - Televison & Video
Is HDMI4 correct or HDMI1?
how many jacks do you have . I would think it will be 1 or 2
Feb 22, 2016 | Dynex Televison & Video
Can't get input on tv to activate rca wi fi streaming media player
depends on what input port you plugged into. HDMI1 HDMI2 HDMI3
the tv input select source has to match
I have a similar device plugged into HDMI3 so I select on the input source HDMI3 to see it on the TV.
Dec 29, 2013 | RCA DSB778W Wi-Fi Streaming Media Player
Hdmi invalid format 1080p
If you put the input from HDMI3 into HDMI2 does the problem follow the input, or does it stay with HDMI3? If it stayed with HDMI3, check the connector visually for damage (cracks, dirt, bent connector). You may have to replace the board, or if you are really handy, the connector. If the problem moved to HDMI2, then look for a cable or device problem.
Sep 10, 2013 | Samsung LN52A580 52 in. HD-Ready LCD TV
Hdmi 3 quit working
My Vizio 42" [MOD V042LFHDTV10A] has a black screen [except on start-up when it displays "HDMI3" momentarily] but the sound works. I unplugged and depressed "On" button for 35 seconds. No change. There is...
If the backlight was the issue, the TV could not display "HDMI3" on the screen. This might be an input issue, unless it happens with every input.
Feb 23, 2018 | Televison & Video
After purchasing a PVR machine from Shaw cable, our Samsung series 6 51" LCD tv requires having the source output on HDMI3. Is there a way to change the " TV " button on the remote to...
We had this same problem on our Samsung 5 series. What we ended up doing was leaving the PVR plugged into HDMI 3 and renamed HDMI 3 to PVR. If you go to your source list and hit the Tools button (i believe its Tools) you should get the option to rename or give a nickname to a particular source.
Jan 10, 2011 | Televison & Video
When I am running movie on my Samsung lcd on hdmi3 it is showing mode is not supported please help
first you have to confirm your tv other hdmi prot working?if yes then there is problem with hdmi prot 3 if you check in side tv there is one drive ic fautly. or your in put signal not same as in put tv.Please change the resulation it will work.
Oct 16, 2010 | Samsung Televison & Video
I cant get any picture on my sony tv when i connect my ps3 upto it, yet get a picture instantly on a cheap 26 inch hd tv. i'm using a hdmi cable on both
Silly question -- but are you sure your Sony TV is on the correct HDMI channel? My 32 inch LCD has HDMI1, HDMI2, HDMI3. You must make sure you plug the PS3 into the correct HDMI channel and make sure you're tuned into the same one.
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
Today all my HDMI jacks except for HDMI3 quit working. I can plug all my devices into HDMI3 with no issues, plug the same components into HDMI1,2,4 and I get the error of no signal. Any ideas besides...
No, typically there are 2 keys written to a TV for the HDCP copy protection. 1 key is usually dedicated to 1 HDMI and the other key handles the others. Sounds like your TV either forgot 1 key or it has corrupted the software which controls the key. The only solution is to replace the main PCB to correct the problem. If this sounds like something you would like to do yourself, post back and I will try to give you some further assistance.
Mar 22, 2010 | Samsung LN40B630 40 in. LCD TV
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
Televison & Video Logo
Top Televison & Video Experts
