How to change am to pm light indicator? - Audio Players & Recorders
    Top Expert:
  • Audio Player... Master
  • 49,128 Answers
Move the clock on 12 hours
Posted on Apr 23, 2017
I have my timer to go on at 4:15pm and go off at 11:00. It does shut off, but goes back on at 4:15 am. What am I doing wrong?
What kind of timer are you talking about? Some timers only operate on a 12-hour window. If yours has a 24 hour window, try changing it to a military time format. For example:
On: 4:15pm = 1615
Off: 11pm = 2300
If you do not have that ability and it only indicates am or pm then program the on time first and ensure it says PM then program the off time and again also ensure it says PM.
Dec 04, 2017 | Dryers
On my Eddie Bauer alarm clock, how do I change the time to pm or am?
When you are holding the set button, advance the time until you see the indicator that you are on PM. Keep going until the PM indicator is gone for AM.
May 26, 2015 | Audio Players & Recorders
I have a Mr. Coffee, Model JWX20 with no instructions. I would like to set it so that it will come on in the morning and brew coffee before I wake up. I can't find a manual. Does anyone know how...
Set the Clock: 1. Plug the power cord into a standard electrical outlet . The clock will flash on the control panel to indicate that the time has not been set yet. 2. Press and hold the HOUR and MINUTE buttons until you reach the current time. The AM or PM indicator will light a t the bottom of the display The clock is now set! NOTE: Pressing any button before setting the clock will cause the clock to start keeping time from 12:00 a.m. You must set the clock if you want to use the Delay Brew feature. To Set the Delay Brew Time: *While the display is in the clock mode, simply press the SET DELAY button and, while the DELAY BREW time is flashing, set the brew time by pressing the HOUR and MINUTE but tons. *The AM or PM indicator will light at the bottom of the clock display. *Within a few seconds the display will change to the current time. The Delay Brew Time is now set!
Jan 18, 2015 | Coffee Makers & Espresso Machines
How do I get my clock radio to change to the PM indicator?
you need to set your time to the correct hour... am for am pm for pm. this mean you may need to cycle past the current hour you Think it is and go to the next example you want 3 pm and it is showing 1AM,,, you go past 3 AM all the way to the next 3 which will be 3 pm.
Oct 05, 2014 | GPX CLOCK RADIO WITH DUAL ALARM
How do i set the alarm on a t231
Setting The Alarm Time of T231
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for
setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows
'OFF' and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the HOUR / REV button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is
'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the MIN / FF button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM 1 button once more to confirm the wake-up time setting or after 10 seconds the display will stop flashing and the new wake-up time will be entered automatically. The
display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. Press the ALM 1 button once more to select the Radio alarm. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
Sep 29, 2014 | Timex Audio Players & Recorders
How do you set the am or pm mode on module No. 3225 3226?
U change the time past midnight you will see a "P" in the upper right hand side near the time indicating PM if nothing is there its AM best way I found out how to do it ???
Jun 14, 2012 | Casio G Shock DW9052 1V Illuminator ...
I have a intermatic ej351c indoor wall switch programmable timer that I have tried several time to program an on time for the lights to come on however the lights does come on. I have followed the...
There might be a couple things that are easy to overlook.
Press the button to see if lights come on >>> if light do not turn on with manual override, then light might be burned out or circuit breaker tripped. Sometimes a breaker is tripped but you can't tell by looking at it
1) The timer is used on incandescent bulbs only. I don't know why, but it says no
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
2) Is the red indicator light ON?
For programs to work, timer has to be in automatic mode and the red indicator light will be ON
The Switch Timer can be used in two modes. manual & automatic
To switch between modes, quickly press the dial twice:
AUTOMATIC MODE: The Switch Timer will turn your lights ON or OFF according to programmed settings. The RED indicator light stays ON when in Automatic Mode.
MANUAL MODE: Programmed settings are inactive, and
the Switch Timer will only turn the light ON or OFF when
you push on the dial.
RED indicator light stays OFF when in Manual mode.
3) setting current time> lets look at the red indicator light while doing this
Move switch lever to OFF-Clear
Move lever to ON >>> red indicator is flashing
Rotate dial to nearest current time (if it's 7:20 pm, rotate dial to 7:30pm)
Press the dial once to set current time > red indicator light goes off
Do not accidentally press dial or it will set the wrong time....ok we know that
4) overlapping programs/
Make a chart of the times you want to program with ON and OFF plus am & pm
Check your chart for overlapping times that tell the timer to do more than one thing
Rotate dial clockwise to the first ON time >> pay attention to am & pm
Press button and first ON time is set
Rotate dial clockwise to the first OFF time >> watch the am and pm
Press button and first OFF time is set
You can have 48 on-off times >>> which seems a lot for a 24 hour repeat timer
5) try the timer with one program
6) If timer still doesn't work, put switch back in and see if lights turn on that way >>> it could be a loose wire suddenly cropped up
Last step >>> timer is no good, you need another one. We tried.
Oct 16, 2010 | Electrical Supplies
I have a HP desktop pc with a RC415ST-PM motherboard, it wont power up when I push the button, it's dead with no lights or any indication that it is operating. I have tested the cable and power supply, ...
Are you using the power button or ru shorting the pins directly? I know these mbs have a bios battery problem. Try to replace the battery and see what happens. The battery on my Rc415st-pm only last a few days and a bios error appears telling you to change battery. Hope this helps.
Jun 21, 2010 | HP (P3035-69002) Motherboard
Developer light and technician indicator were on
Hello sir; That's PM light, you may go to simulation 20, 21,and 26 to reset; Press"#" "interrupt" "c" "interrupt' then enter 20 press print enter 01 press print, to clear PM counter, now same procedure go to simulation21 and 26, on sim.21 sub code 1 set no PM at 1, on sim 26 sub code 36 set on 1. after all done press clear to exit.
Jul 24, 2009 | Sharp AR-5316 Advanced Digital Imager...
Diesel light sensor comes on
When was the last PM? With the oil change the fuel filters should of been done and before the filter in the engine compartment was removed the small yellow drain valve should have been opened. If it was then maybe you have a little water in the tank. that light should be an indicator for water in fuel.
May 08, 2009 | 2000 Ford F350 Super Duty Super Cab
26 people viewed this question
 Grubhead
Grubhead
