Question about LG Televison & Video
Problem in LG 42"led TV model 42LN5400,afterstart screen flashes every 5sec remain off. After running flash light test i found that there is display on TV and fine audio as well but no display at all.
    Top Expert:
  • LG Master
  • 74,459 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 23, 2017
SOURCE: samsung 42' plasma tv,screen keep flashing, blurry,no pics
I'm not really sure what causes this but I might be able to help.
I have an LG 42 plasma which had the same problem. In my case I removed the video and the tuner board (they both were mounted on the same frame which was screwed on the tv chassis) and installed them in a "wooden box" so that there would be no electrical contact with the rest of the chassis except from the cables connected to them. It now works fine.
Posted on Feb 23, 2009
  • 6 Answers
SOURCE: lg 42" hd 1080p
This could be bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Posted on Apr 29, 2009
dsacco86
  • 1077 Answers
SOURCE: flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Posted on Jul 20, 2009
SOURCE: 42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Posted on Dec 08, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
Aug 31, 2017 | LG Televison & Video
My LG tv model number 42LN5400-UA no picture
It is a common problem for the LG 42/47 LN series LED TV, the problem is defective LED back lights strip (strips).
You have to open the display panel to find the bad one & replace it. The part number usually is printed on the strips, read 6916L-11XXA, you may purchase it from EBay.
Aug 11, 2017 | LG Televison & Video
If I replace the LED driver, do I also need to replace the back light strips?
Hello, those sets are notorious for the LED strips failing. I have replaced dozens of them. If your going to replace them, be sure you replace them all! Pat # is LC420DUE-SFR1 LED Strips. Thanks
Apr 27, 2017 | LG Televison & Video
What's wrong with my LG 55LV9500 LED TV? Power on, black screen.
Hello, either the power supply is failing to power up the LED's or the LED strips in the screen have failed, a common issue with these sets. Power supply part # is EAY62169701. LED strips are only available as a complete screen assembly from LG....thanks
Apr 23, 2017 | LG Televison & Video
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
Lg 42" tv not displaying screen image
The t-con board controls the picture. To test it shine a flash light on the screen abd see if you can see an image when the TV is on. If you do then the T-con board is OK. Look at the back light ballast board (sometimes is part of the power supply board) If you see no movement or a dim picture with the flash light, then the T-con board is gone. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | LG Televison & Video
What could be wrong with my TV? The audio and video suddenly cut out.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 15, 2016 | LG 42" 5400 Series LED HDTV - 42LN5400
My LG 42LN5400 LED TV turns off and on in an endless loop. There is some light on the screen when it comes on, but then goes black before turning off. What part needs to be replaced to fix this?
seems like the issue with the power circuit .. the LED must be fine that is why you see the back light when powering on ..
do not replace any parts manually, call in a technician, incorrect part can do more harm than good.
Jul 23, 2015 | LG 42" Ln5400 Series Led-Lcd Fu1080P...
Televison & Video Logo
Computer Repairing
Computer Repairing
