Question about Coffee Makers & Espresso Machines
I have a black and decker coffee maker and it doesnt keep the coffee hot. Why is that because we havent had it that long.
SOURCE: Black & Decker TCM700 Coffee Maker problem
the concept still applies. the heating element is usually dual functional. heating the water then keeping the plate warm.
Posted on Mar 11, 2007
SOURCE: black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Posted on Jun 01, 2009
SOURCE: directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Posted on Nov 14, 2009
SOURCE: replacement carafe for Black & Decker ODC325N Spacemaker 12-Cup
You can have mine for the cost of shipping
Posted on Dec 04, 2009
lmmuresan
  • 131 Answers
SOURCE: Series ODC150-325 Black and Decker Spacemaker Coffee Maker
Often there are hard-to-find Black & Decker Spacemaker coffee maker parts here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=black+decker+spacemaker&submit=Search&_sid=93311479
Posted on Sep 13, 2010
My black and decker coffee turns on but wont brew
You have a problem with your internal hot water heater which for most folks ( the vast majority who can not take apart a coffee maker and change its internal components) this means that your coffee maker is dead
Jul 05, 2014 | Black & Decker Coffee Makers & Espresso...
My coffer maker brew basket keeps overflowing. I've deduced that when I push my decanter into the machine, there is so much give that the plastic arm in back pushes it forward and stops the coffee from...
Hello, Srober48 -
Since your Black & Decker coffee maker is only a few months old, it is most likely still covered by warranty.
I suggest you call the Black & Decker Customer Service / Support telephone number printed in your owner's manual / instructions and find out if you can take the coffee maker to an authorized repair center (for free, warranty-covered repair) or if the company will provide you with a replacement coffee maker.
Note: I suggest you do not try to repair the coffee maker yourself while it is still covered by the warranty.
Best wishes.
Feb 04, 2018 | Black & Decker DCM100 12-Cup Coffee Maker
Leaking black and decker under counter coffee pot
the 90 degree red elbow has worn away of hot water temps and will leak some but all hot water to the bottom of machine. needs to be replaced or retrofit one
Jan 03, 2010 | Black & Decker SpaceMaker ODC440B 12-Cup...
Doesnt work
The thermal cutoff switch is probably stuck (blown) open and won't reset. It mounts on (against) the heater unit, and the part number is 36TMH0110603L320-32F (cuts off between 320 and 332F). I can't find any for sale, but there is a slightly different one available which cuts off between 315 and 350F. The problem is I can't find an outlet that sells singles of those. If you can find someone who sells individual parts with serial no: 36TMH0110539L315-50F let me know.
Oct 28, 2007 | Black & Decker SpaceMaker ODC325 Coffee...
All coffe makers have a thermal cutoff fuse located on the bottom heating plate. It is usually in series with one of the leads to the actual heater. This should read "short" with an ohm meter. If it is "open" it needs replacement. They are rated in Degrees celsius, and are sometimes difficult to find. Black and Decker may be able to send you one.
Mar 11, 2006 | Black & Decker TCM700 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
