Question about Ematic Audio Players & Recorders
Im seeking the firmware upgrade/update for an ematic digital converter box with led and recording
SOURCE: I need an diver update for my firmware my dive is a Digital Research Technologies DVDRW 1004 m
i wanna go on aim in ma clas but it wont let me !!!!!!!! but others know how i i aint g ask cuz..
Posted on Jan 17, 2008
SOURCE: record to vhs with converter box
I need to leave my TV on channel 3 and set the converter to the channel I want to record. When programming for future recording, it's always from channel 3, not the channel I want the converter displaying.
Posted on Jul 18, 2008
Bajanguru
  • 7752 Answers
SOURCE: How to Firmware/software upgrade on Razaor V3i?
yes you need to take the phone and have the firmware reflash on the phone to correct this issue...any mobile repair center should be able to get this done for you.
Posted on Dec 28, 2008
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
  • 30 Answers
SOURCE: I have a new digital tv but can't get my vcr/dvd
The output connection from the VCR/DVD needs to be different for the new digital TV. Instead of using the RF output from the VCR, use the video and audio outputs and connect them to the video and audio inputs on the digital TV. When you want to watch the VCR, select "video in" on the TV. The digital converter box should be hooked to the input of the VCR so you can record programs off-air.
Posted on Jun 15, 2009
How do I upgrade my Emactic AT103B converter box from usb?
As far as I can tell, there is no firmware update available for the Ematic AT103B. If you do have a firmware file for this converter box, plug in the USB drive when the converter box is on. Then press Menu and go to the System Setup (the icon has a gear and is labeled Settings) menu option with the Left/Right arrows. Press the Down arrow and continue down to the Software Update line. Press OK. Select the correct file. (If this file isn't shown, try inserting the USB drive after reaching this line.) Press the right arrow to start the upgrade process. Do not let the unit power down during the upgrade.
See page 14 (page 15 of the PDF) and the preceding page to see how to navigate the System Setup menu. The manual is available here: https://ematic.zendesk.com/hc/en-us/articles/220756147-AT103B . The direct link to the manual is currently: https://ematic.zendesk.com/hc/en-us/article_attachments/208176947/AT103B_manual.pdf .
I hope this helps.
Feb 03, 2018 | Televison & Video
Ematic AT102 How do you program it to receive the cable channels when no cable box is needed?
Unfortunately, the Ematic AT102 does not have a tuner for cable television. It only has a ATSC (digital over-the-air) tuner. You need to connect it to an TV antenna and then search for channels. Depending on where you live, you may need an external antenna to get sufficient signal strength to receive local channels. See http://www.tvfool.com for signal strength information in your area.
Older cable signals are NTSC (same as analog over-the-air). Newer digital cable is QAM. (Some channels are broadcast as clear QAM which don't need a cable box with some tuners/TVs.)
To record your cable, you will need a different type of DVR/set-top box. An old VCR or DVD recorder with an NTSC tuner would work to record analog cable. There are a few ATSC converter boxes that also support clear QAM. This is one of the models: http://www.solidsignal.com/pview.asp?p=CM-7003 .
I wish that I had better news for you. Other options are available for NTSC, ATSC or QAM tuners. Please add a comment with more information about your cable service if you'd like extra information on these options.
Feb 23, 2017 | Televison & Video
Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Dec 08, 2016 | Televison & Video
Program my g.e remote control to a A.T.103 gematic digtal box
Tv Converter Box Deals
www.bestdeals.today/tv-converter-box
Digital Converter, Ematic Digital TV Converter Box with Recording, Playback, ...Digital to Analog TV Converter DTV Tuner Box w Remote, Program Guide, PLUS MORE! ... GE Television Antennas Omni TV Indoor Antenna 24731 ... HDMI/HDTV/DTV/RF/RCA/USB Digital Converter Box TV Tuner With Remote Control PVR.
Ematic DVR Recorder Television HDMI Media Player ...
www.altatac.com/p-15751-ematic-dvr-recorder-television-hdmi-media-p...
Ematic DVR Recorder Television HDMI Media Player Converter Box w/ USB ... TheEmatic AT103B Digital Converter box allows your TV without a digital ... Features an electronic program guide, parental controls, and a USB ... Full function remote controlincluded. .... My Account My Account Order Status Track Your Order.
At103b Ematic Converter Digital Atsc
antennadisht.com/at103b
11 ozmiscellaneouspackage contents converter box remote control 1 x user ... Review (mpn:at103b for sale) Digital Converter Atsc Ematic At103b Box . ... You can find your tracking number by ing on my and scrolling down to your purchase with us. ... Features an electronic program guide, parental controls, and a usb ...
Jan 24, 2016 | Televison & Video
How do I get a passcode for a ematic digital converter box AT103B
Just use all zeros for the pass code which is the factory default.
Feb 21, 2015 | Ematic Audio Players & Recorders
Hello, i have an ematic mp3 and video recorder and i downloaded the video converter but my videoes have no sound or are slowed and split
convert again your video but with lower bitrate video and use sound codec that support with your media player, see the manual to check the video and audio codec that compatible with your media player
Feb 15, 2011 | Beond Ematic EM304CAMB Digital Media...
It needs aac upgrade
My RCA Pearl gave me the AAC firmware message with some files until I followed all the troubleshooting instructions that popup when running the firmware update software. The firmware with AAC upgrade is here.
Follow these instructions and it will work:
run the firmware update software software,
reset the player by removing the battery or holding the power button for 10s for players with internal batteries,
hold the play button while inserting the unit into usb,
release the button once the software changes from "searching" to "initalizing",
check the box to format the data on the player,
and click start.
When I did this update without formatting, the aac fix did not work. I
Sep 20, 2009 | RCA Pearl TH1102 MP3 Player
Cannot find music files on my ematic mp3
To do a search on your computer just goto START, then SEARCH. Click on "All Files and Folders". In the search box, type in *.WAV or *.MP3. This will search your entire computer for WAV files or MP3 files. To convert WAV into MP3, you will need to download a program from the internet that cnverts WAV into MP3 files. Just goto google.com and type in WAV to MP3 converter and should be able to download free converters....
May 30, 2009 | Beond Ematic EM304CAMB Digital Media...
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Memory Frame model 810
Dis you ever get the firmware upgrade?
Aug 24, 2008 | Pacific Digital MemoryVue MV-800 Digital...
535 people viewed this question
Top Ematic Audio Players & Recorders Experts
Lawrence Oravetz
Are you an Ematic Audio Player and Recorder Expert? Answer questions, earn points and help others
