Question about Welding Tools
Good air at regulator. But no air coming out of the plasma cutter nozzle. What is the problem
    Top Expert:
  • 49,170 Answers
Blocked air line to cutter , air control solenoid not being energized by the cutter trigger
Posted on Apr 23, 2017
Hobart 400 plasma cutter. when i hit the trigger nothing but one short blast of air.
Make sure you have a good ground. If ground is good, make sure you are holding the tip level to the work and right up close.
Aug 31, 2011 | Hobart Plasma Cutter - Airforce 400
What kind of air compressor do you need to run a plasma cutter? (how many psi, gallons, volts... and any other info...?)
Hi:
You will need at least the following:
25 CFH at 120 PSI
30 gallon reserve tank
220 V single or 3 Phase (that depends of your voltage available at your shop/home)
For cutting: set your plasma regulator to 75 psi.
For Gouging: set your plasma regulator to 65 psi.
That's all.
Aug 02, 2011 | Lincoln Welding Tools
I have a plasma cutter mode 40D. when I first got it about a yr. ago I tried it and it seemed fine. Went to use it on the weekend. Hooked up my air compressor to it and everything else hooked up and can ...
The fan you hear is the cooling fan for inverter.
The air pressure is delivered by the air compressor, through the air filter/regulator device.
Check what is the pressure of the compressor, and the regulated pressure on your pressure gauge (if you have in the front, or may be in the rear of your cutter).
Jun 21, 2010 | A & A Manufacturing Ramsond 40D Plasma...
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
When air is hooked up it blows the air regulator and all the air blows out valve very little gets to gun.red safety light comes on on front of machine and it will not work
Air pressure should be no more than 90#s. If regulator cannot handle at least 125#s . Get a new regulater. Sounds like this regulator has a blown diaphram.
Nov 11, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
Pull the trigger ,air comes out no fire
Ck the ground and the condition of the tip. The more it gets concave the harder it gets to get a arch. Gun angle is also important, hold at right angle to work and don't forget a very good ground.
Nov 03, 2009 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Troubleshooting help
I would recommend replacing the electrode, and maybe the tip, other that that it sounds like you aren't getting a good enough ground for it to start.
Aug 23, 2009 | Hobart 500474 Airforce 400 Plasma Cutter
Plasma cutter wont cut steady
Is your air compressor able to keep up with the continuous regulated air flow?
If positive air flow is not constant same pressure all the time
cutting will stop..>>
Also if your movements are to fast and or material to thick machine will behave that way..
Jan 22, 2009 | Hobart Welding Tools
Plasma Cutters support
In this process, an inert gas (in some units, compressed air) is blown at high speed out of a nozzle; at the same time an electrical arc is formed through that gas from the nozzle to the surface being cut, turning some of that gas to plasma. The plasma is sufficiently hot to melt the metal being cut and moves sufficiently fast to blow molten metal away from the
Aug 27, 2008 | MILLER 192049 SWIRL RING PLASMA CUTTER
Welding Tools Logo
564 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
