Question about Air Tools & Compressors
No air coming out of plasma nozzle. Air at regulator
2 Suggested Answers
  • 48271 Answers
SOURCE: Good air at regulator. But no air coming out of the plasma cutter nozzle. What is the problem
blocked air line to cutter , air control solenoid not being energized by the cutter trigger
Posted on Apr 23, 2017
Apr 23, 2017 | Welding Tools
Air in tank
the air bleed for the tank is not allowing the air to come out as the fuel is going in. Reduce the flow rate at the nozzle to allow that air out past the nozzle.
Jan 08, 2014 | Hyundai Accent Cars & Trucks
What kind of air compressor do you need to run a plasma cutter? (how many psi, gallons, volts... and any other info...?)
You will need at least the following:
25 CFH at 120 PSI
30 gallon reserve tank
220 V single or 3 Phase (that depends of your voltage available at your shop/home)
For cutting: set your plasma regulator to 75 psi.
For Gouging: set your plasma regulator to 65 psi.
That's all.
Aug 02, 2011 | Lincoln Welding Tools
Hi, Is there of clearing the drain hole from the back of the fridge? Mine is blocked and so water is condensing and settling under the salad tray. Thanks
a little air pressure works the best. if you have an air compressor or a portable air tank, usa a blower nozzle. if you can regulate the air then turn id down low, like 15 pounds or so. stick the nozzle in the drain opening inside the fridge and wrap a rag around the nozzle at the drain opening to prevent blow back. give it a quick burst of air and it should be unblocked. if not then give it a little more pressure. after its clear then pour a little bleach water down the drain to kill the slime . good luck
May 28, 2011 | Refrigerators
I have a plasma cutter mode 40D. when I first got it about a yr. ago I tried it and it seemed fine. Went to use it on the weekend. Hooked up my air compressor to it and everything else hooked up and can ...
The fan you hear is the cooling fan for inverter.
The air pressure is delivered by the air compressor, through the air filter/regulator device.
Check what is the pressure of the compressor, and the regulated pressure on your pressure gauge (if you have in the front, or may be in the rear of your cutter).
Jun 21, 2010 | A & A Manufacturing Ramsond 40D Plasma...
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
When air is hooked up it blows the air regulator and all the air blows out valve very little gets to safety light comes on on front of machine and it will not work
Air pressure should be no more than 90#s. If regulator cannot handle at least 125#s . Get a new regulater. Sounds like this regulator has a blown diaphram.
Nov 11, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
Air is coming out but no primer
  1. primer viscosity to thick
  2. internal filter clogged
  3. internal passage clogged
  4. gun not adjusted properly
  5. high build primer uses more air pressure
  6. wrong needle and fluid nozzle
  7. gun needs cleaned
Aug 07, 2009 | Vaper 4 Piece Set 3 Gravity Spray Gun +...
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Apr 05, 2009 | Garden
Plasma Cutters support
In this process, an inert gas (in some units, compressed air) is blown at high speed out of a nozzle; at the same time an electrical arc is formed through that gas from the nozzle to the surface being cut, turning some of that gas to plasma. The plasma is sufficiently hot to melt the metal being cut and moves sufficiently fast to blow molten metal away from the
Air Tools & Compressors Logo
51 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
