Question about The Office Equipment & Supplies
I want to buy more beautification for my island but when I try to buy it won't let me! The green check mark is not highlighted! Why?????
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
Has anyone bought the Bradley furniture alpine kitchen island?
My friend bought it and was very satisfied with it. The price was a bit too high for him. But he managed this problem with a help of bad credit installment loans
Sep 10, 2012 | Furniture
I need to get the ice and fire arow
Use your Teleport song thing to teleport to Mother and Child Isles. If you can't teleport yet, find Cyclos and shoot him with your arrows until you get to the cut-scene where he teaches you the song. You may have to try a few times to get it. Make sure you have as many arrows as you can carry when you run into him. Aim low and to his left. If that doesn't work the first time, you might try moving the joystick all over the place, just aiming in his general direction, shooting constantly. If you save just before he starts sucking you into his whirlwind, you can restart the game and you won't have to buy more arrows.. If you don't know where to find Cyclos, he always hangs out around Shark Island, Mother and Child Isles, and a couple other islands. Hope this helps.
Jan 18, 2012 | Nintendo The Legend of Zelda: The Wind...
I installed a new router on our small network and now our hp 4600 color laserjet printer shows offline and will not come online no matter what I try.
First, make sure your Router is configured for DHCP, and the Printer is plugged into the Router using a Network Cable. Also, make sure the Activity light on your Router is On for the Port that your plugged the Printer into.
Configuring TCP/IP parameters
You can use the printer control panel to configure the following TCP/IP parameters:
  • usage of the BOOTP file for configuration parameters (the default is to use the BOOTP file)
  • IP address (4 bytes)
  • subnet mask (4 bytes)
  • default gateway (4 bytes)
  • TCP/IP connection timeout (in seconds)
Note: Do not disable BOOTP if you will be using RARP or DHCP to configure TCP/IP parameters.
To automatically configure TCP/IP parameters from the printer control panel:
1. Press the Check Mark button to enter the MENUS.
2. Press the Down Arrow to highlight CONFIGURE DEVICE.
3. Press the Check Mark button to select CONFIGURE DEVICE.
4. Press the Down Arrow to highlight I/O.
5. Press the Check Mark button to select I/O.
6. Press the Down Arrow to highlight EIO X (where X = 1, 2, or 3).
7. Press the Check Mark button to select EIO X.
8. Press the Down Arrow to highlight AUTO.
9. Press the Check Mark button to select AUTO.
10. Press the PAUSE/RESUME button to return to the READY state.
Here is your Manual, with more information about Network Configuration:
http://business.fsu.edu/tech/printermanuals/laserprinters/HP4600.pdf
Jun 18, 2011 | HP Color LaserJet 4600n Printer
Where i can find the next gem in sevii island?
On the lower levels of the mountain on Island one you may have noticed two Rocket Grunts talking to one another. Those are your targets. However, you must first talk to Celio in the One Island Pokemon Center before they'll fight you. Beat them both to unblock the way into the cave they dug for you. Beating them also gives you a password for later use.Then on Six Island:To get the second password you need to do the hole puzzle on Six Island You must fall down the one correct hole out of four several times, or be sent back to the beginning. So here's how to proceed: first take the north hole, then west, then east, then south. And now you know the second password
Mar 26, 2010 | Nintendo Pokemon Leaf Green for Game Boy...
I bought a CECT P168 iclone phone and I don't know how to set it to vibrate only
  1. Click "System"
  2. Click "User Profiles"
  3. Click whatever profile you are currently using. (It should be the one already highlighted with the green check mark to the left of it) and then click option 2, "Customize".
  4. Click option 3, "Alert Type", and set to "Vibration Only".
Taa-daa!
Jul 19, 2008 | Lands Phones
Convergence problem? or something else? HELP!!
Does the TV have a "Magic Focus? button on the front of the TV? If you try the magic focus does it complete or does it halt with an error code?
Apr 27, 2007 | Hitachi 50GX20B 50" Rear Projection...
22 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
