Question about Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 206 maintainance service m2 how to set this problem
  • Konica Minolta Master
  • 6,168 Answers
Did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
Posted on May 06, 2017
No drum replace & developed replace how to sole konica minolta bizhub 206 error code m2 reset
did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
Apr 23, 2017 | Konica Minolta Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
What would be the genuine problem when konica minolta bizhub 215 shows maintainence call(m2)
Procedure
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Apr 03, 2014 | Minolta bizhub 180 Black and White Copier
Konica bizhub 164 M2
1-Press "Menu
2-press Quick settings,
3-then press right arrow key 2 times
4-press Quick settings
5-then press left arrow then right arrow key.
Feb 26, 2014 | Konica Minolta bizhub Office Equipment &...
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
Konica Minolta bizhub 210 error m2 appear on display
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
78 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
