Reset maitainace service code m2 - Office Equipment & Supplies
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
What is solution for konicaminolta 164 maitanance call m2
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.
1-Press utility button on panel.
2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.
3-its the code to get into service mode.
4-After pressing above mentioned buttons you will enter into service mode.
5-Now select service choice option.select it by pressing OK button.
6-In service choice option you will see Maintenance count option.
7-Select it by pressing Yes or OK button.
8-There will be three options 0,1,2.
9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Jul 04, 2014 | Konica Minolta bizhub Office Equipment &...
Code m2
menu,quick setting,<<quick setting <> and go to service choise ,maintenanc 0 press sit down go to clear data and clear maintenanc and supplies
May 16, 2014 | Konica Minolta Office Equipment & Supplies
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
Code m2 erreur minolta 5000
M2 mean s to remove the Waste Toner box in the back of the machine. Replace with a new one and reset the counter in service mode.
Nov 27, 2012 | Minolta EP4000/5000 CS/PRO Copier
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
Maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Dec 17, 2010 | Minolta bizhub 180 Black and White Copier
Konica Minolta bizhub 210 error m2 appear on display
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
Code m2
M2 is a maintenance code, it is usually tied to one of the machines consumable products, drum, developer, or fuser rollers. These items should be checked before attempting to reset the code.
Hope this helps.
Ed
May 11, 2009 | Konica Minolta DiALTA CF910 Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
19 people viewed this question
k24674
