Question about Star Heating & Cooling
Display shows F2 in blue star window AC - Star Heating & Cooling
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Posted on Jul 25, 2010
Testimonial: "Thank you"
  • 23 Answers
SOURCE: in our onida split ac
room or pipe thermistor error
Posted on Apr 13, 2014
steves_here
  • 1692 Answers
SOURCE: Gree ac showing on display F2
Hi Younis, I found the code on the link below, I hope this helps.......... CHEERS..
F2 ambient temp. sensor fault
1? Check whether the resistance of sensor is normal, otherwise replace it.
2?Check whether the sensor wire is short circuit or open circuit, and whether the plug is well contacted, whether there is welding off or rosin joint on the electric control board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components or integrated circuit is damaged, the electric control board should be replaced. http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
Posted on May 07, 2016
Blue Star 1.5 ton 5 star inverter split AC remote "TEMP" button seems not functioning. does any one help me? how to check this function as always remote is showing set temperature.
does that on mine as well
the temp is what is on the inside wall unit when turned on the remote reads 25 and the inside unit reads 30 but eventually comes down to 25
Apr 14, 2017 | Star Heating & Cooling
Blue star split ac showing ec
What is the model of your heating unit. With out that information i cant help you with your ac repair problem. If you have any other AC Repair Questions don't be afraid to let us know.
Oct 21, 2015 | Heating & Cooling
My onida ac 1.5 [window] .ac on ,display code F2. why?
Your Air Conditioning problem seems to be a leak that reduces the refrigerant charge. you have to find/fix the leak and recharge the unit...
http://www.fixya.com/support/t10595851-onida_window_ac_1_5_ton_displaying_f2
Sep 12, 2013 | Office Equipment & Supplies
Whirlpool matermind window AC shows error code F2 when power on and won't cool. Sometimes it starts up perfectly fine.
F2 ---for me its a sensor problem had it done thanks katsaras
Unit -- Whirpool AC Model no. Wasr18k20 1.5 ton split AC
Jul 25, 2012 | Heating & Cooling
E9 ERROR IN HITACHI AC
HI
MY HITACHI WAC MODEL for 1.5 lr, DISPLAY SHOWING E9 ERROR CODE. ALREADY COMPLAIND TO HITACHI CUSTOMER CARE, BUT NOT GETTING POSITIVE RESPONSE. NOW CAN YOU PLESAE LET ME KNOW WHAT DOES THAT (E9) ERROR MEANS AND HOW TO RESOLVE THE SAME?.
THANKS
Jul 04, 2012 | Heating & Cooling
LP,HP AND CF APPEARS ON HANDSET AFTER RUNNING THE UNIT IN BLUE STAR DUCTABLE UNIT. PLS SOLVE IT
after starting of ac units it shows lp hp but once reset than the lp hp thing goes away what is the reason for showing lp, hp in the morning when started first time in the morning
Apr 28, 2011 | Heating & Cooling
When I press my power button 3 or 4 time (on off) or some time more then display show in monitor. when I press 1st time then the pc start but no display show in monitor. when I off it and then again on it...
CHANGE CMOS BATTERY OF YOUR SYSTEM IT COSTS 10 RUPEES ONLY. ERRORS WILL GONE AFTER CHANGING THIS BATTERY. SYS WILL START IN SECONDS AND F2 ERROR WILL DISAPPEAR
Mar 29, 2010 | ASUS P4PE2-X Motherboard
Heating & Cooling Logo
56 people viewed this question
Top Star Heating & Cooling Experts
paulcarew
Joseph Coppeto
Joseph Coppeto
Tom Chichester
Are you a Star Heating and Cooling Expert? Answer questions, earn points and help others
