Question about Emerson Computers & Internet
Emerson tv turns on and gets past digital television, and shows "hdmi1" or "pc" etc in the corner, but stays with saying that in the corner no matter if the device is connected or not. Help
Essentially the name of the source stays in the corner of the screen and even if you connect a device, it doesn't show up on the screen it just remains black with the source in the corner of the screen
    Master:
  • 604 Answers
Replace the main control board
Posted on Apr 23, 2017
My seiki tv got turned on to hdmi1 mode. How do I turn it off. I don't have an hd tv. The screen is blue and it says hdmi1 at the top and no signal.
you need to press source on the remote. That will let you choose what signal to use. TV, hdmi1, hdmi2, and more options will show
Oct 23, 2016 | Seiki Televison & Video
Why can't my TV find a digital signal when connected to my digital ready aerial? Tuning for digital stations finds none. Does this TV require a set top box? If not how can I make it find and play n
hey, when connect any aerial in the back of the TV make sure you have a look for the name of the connection you use ( Skart,ext1,ext2,usb,hdmi1, hdmi2 etc.) so you can do a search on that extension. if you connect something on Hdmi1 and search on hdmi2 you won't find anything. you have to search on Hdmi1. PS: good luck.
Jan 24, 2015 | Televison & Video
Emerson LCD TV misfunctioning
Remove the connector that goes to the remote board and see if it stays then, if it does that board needs replacing, its not an expensive board, if it still changes on its own then its the main board that is bad, that one is much more money.
Feb 08, 2018 | Emerson LC320EM8 32 in. LCD TV
Won't stop scrolling through channels
This television is defective and either needs a software update or to be replaced.
Dec 02, 2013 | Emerson Lc320em1 TV
The power stand by light is on when i push the power button it stays red, the after a while of pushing the button it turnes green but all i get is a blue screen
YOU NEED TO CHANGE THE INPUT OF YOUR TELEVISION SET TO THE CORRECT SOURCE. FOR EXAMPLE: HDMI1, AUDIO VIDEO IN, YPBR INPUT ETC, YOU CAN DO THIS BY THE USE OF YOUR TV REMOTE.
Aug 14, 2013 | Apex Digital DT502
I own a 20" Emerson digital/Analog television
Your Emerson TV has been switched to video input. No video input = no picture.
Mar 03, 2018 | Emerson Televison & Video
What's my tv code.... I'm have a Emerson tv.
Hello
Three digit universal remote codes for Emerson TV are:
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit codes are:
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 12, 2012 | Emerson Televison & Video
My ps3 is hooked up though HDMI to my emerson lc195emx. but the tv says its an unsupported format. why? is it because the tv only has 720p out put??
Try turning off the power to your console using the power switch in the back (first shut it down properly). Unplug the AV cables (if applicable) and the plug in the HDMI cable. Turn on the system and switch your input on your Television to HDMI. (Keep in mind that there may be a few inputs; HDMI1, HDMI2, etc.) The HDMI connection takes a few seconds so be patient. If that doesn't work, re post or ask to chat.
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
I need code for tv
Hello
Three digit universal remote code for emerson are:-
Four digit universal remote code for Emerson TV/vcr combo are:-
0456 [0458 0227]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Also try these four digit codes for Emerson Tv also. There are so many codes for Emerson Tv.
Nov 26, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Computers & Internet Logo
62 people viewed this question
Top Emerson Computers & Internet Experts
Stan Skaggs
Stan Skaggs
ray gallant
FireballXL55
Are you an Emerson Computer and Internet Expert? Answer questions, earn points and help others
