Question about Food Mixers
Tripped circuit & heard pop on KA Artisan Mixer #RRK150 while using pasta press attachment. Now doesn't run. Fixable OR replace?
  • 19,110 Answers
Probably fixable. The load of the pasta press may have blown an internal fuse or overheat thermostat, taking the breaker with it. Open it up and take a look.
Kitchen Aid Artisan Mixer RRK150 spares Google Search
Posted on Apr 23, 2017
  • 118 Answers
SOURCE: need user manual
Looking on the KitchenAid site, your model did not look up, buyt I put miune in and this is the link to download the manuals.
Posted on Nov 30, 2008
  • 12 Answers
SOURCE: the pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Posted on Mar 16, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Grinding noise when running.
It very likely sounds like a plastic gear that is worn. If this is the case, then a replacement is very likely stocked by the manufacturer only.
I advise opening the unit to identify which one you need, then 'phone the manufacturer with the make model and year of the product.
If they say they do not stock it - then I'm afraid that's as far as you can go with this.
Posted on Aug 16, 2009
co7196
  • 3433 Answers
SOURCE: The mixer attachment is stuck on my Artisan stand
Turn it back and forth, may be jamed in locking mechanism/slot.
Posted on Oct 28, 2009
  • 5 Answers
SOURCE: Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Posted on Feb 20, 2010
Why is my pasta attachment spinning?
There is a pin on the tapered spindle that fits into a grove in the mixer. If the attachment is not pushed far enough into the mixer housing and screw is not locked down the attachment will spin. It is possable that ihe pin on the attachmen t is sheared off.
Oct 13, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Stop the pasta attachment from spinnig
I am assuming that the whole attachment is spinning. To forestall this, make sure that the attachment is fully inserted in the attachment hub and that the small protrusion is seated in the notch just in front of the attachment knob and tighten the knob.
Kitchenaid Artisan Stand Mixer has stuck hub bevel gear (KSM150PS)
The bevel gear sits above the worm-follower gear. I think you mean the drive attachment gear.
I think I have the same, or similar problem. I ground a piece of meat that stopped it from working. The drive-attachment-gear turns if I push it in, but then it pops out. I am still trying to figure out what part is causing the issue - the drive attachment gear, or maybe even the worm follower gear.
Feb 24, 2013 | KitchenAid KSM150PSGR - Artisan Series...
The machine seems loose and it rocks. Also, the pasta attachment (meat grinder) will not lock in. Can I adjust where the grind worm goes in?
Hello Darlenescott,
About the machine rocks, the whole machine rocks or just the Head? If it is just the Head you may want to check to see if the set screw that holds the lock in place is still there or lose. The scress is located on the right side of the machine if you are looking straight at it in use. It is at the bottom of the head close to where the head attaches to the pedistool. If it is missing post back to this discussion and I will find the part # and place that you can purchase the part.
The second issue, the pasta attachment is not locking in properly. There is no way to ajust how the pasta attachment fits. I would try and return the attachment and exchange it for another as they are mass produced and may not have got the shaft down to the proper tolerances to fit.
I hope this helped and please post any other questions you have to this thread.
Thank you for choosinf FIxYa for your solution.
Mar 06, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
Aug 02, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I bought a ice cream maker from the US unfortuneatly the drive assembley isn't the right fit for my kitchenaid. Do you or can you help me find the right part? Kind regards Robyn Ricketts
Hi ROBYN, Happy New Year! First a couple of clarification questions: A) Was your ice-cream maker a Kitchenaid (KA) Ice Cream maker, too, and B) was your mixer purchased after 1990? If you purchased a KA Ice Cream maker and your mixer is less than 20 years old, according to KA, the Ice cream maker should fit all mixer produced after 1990.
If you have a different brand (not KA) of ice cream maker, then I’m afraid you just won’t just be able to replace the drive assembly, but you will also need the correct dasher (the scraper inside the freeze bowl), as such you probably would be better off purchasing a KA Ice Cream Maker, which would be compatible with your mixer. Of course if your mixer is over 20 years old, then even if you have a KA Ice Cream maker, it may not fit correctly anyway, which leaves you in a conundrum. Should you purchase a new KA mixer for your KA Ice Cream maker or do you purchase a new KA Ice Cream Maker to go with your current KA mixer produced after 1990?
You can download the KA Ice Cream Maker Use & Care Manual from the KA website at: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KICA0WH_Use%20and%20Care_EN.pdf
I wish I could offer you a better solution to use your new ice cream maker with your current mixer, but unfortunately I am unable to do so.
I hope this was helpful, even if it doesn’t provide you the answer you were looking for. Good Luck, Howard, Burke, VA. If this solution was helpful though, please rate it. hslincoln
Jan 10, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Mixer runs ,then stops, and now has lost all lower speeds.
Hi DALE, from the symptoms you describe, it sounds like you've got problems in your (speed) control assembly. If your mixer were out of warranty, I'll tell you that you could fix it yourself, but as your mixer is less than one year old, let KA fix it or replace your mixer on their dime. Contact them immediately and tell them about your problem with the speed control.
The KA website is at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Contact Us> and the toll free phone number is listed to speak with someone. You can also look under the Warranty & Service Plans to see what KA will do for you. I've extracted parts of it here:
Hassle-Free Replacement Warranty
We’re so confident the quality of our products meets the exacting standards of KitchenAid that, if your mixer should fail within the first year of ownership, KitchenAid will arrange to deliver an identical or comparable replacement to your door free of charge and arrange to have your “failed” mixer returned to us.
Your replacement unit will also be covered by our one year full warranty. Please follow these instructions to receive this quality service.
If you reside in the United States and your KitchenAid® mixer should fail within the first year of ownership, simply call our toll-free Customer Satisfaction Center at 1-800-541-6390, 8 a.m. to 8 p.m.,
Monday through Friday, 10 a.m. to 5 p.m., Saturday, Eastern Time. Give the consultant your complete shipping address. (No P.O. Box Numbers, please.)
When you receive your replacement mixer, use the carton and packing materials to pack-up your “failed” mixer. In the carton, include your name and address on a sheet of paper along with a copy of the proof of purchase (register receipt, credit card charge slip, etc.).
I hope this helps. Good Luck with KA! - Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 19, 2009 | KitchenAid KSM150PS Artisan Series Stand...
The pasta/meat grinder attachment stops turning
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Need bowl and mixer attachments for Kitchen Aid Artisan Mixer
We've found most all accessories at any place that sells the mixer. Bowls, beaters, meat grinders, pasta makers, etc.
Jan 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Need user manual for Kitchenaid Artisan Series Mixer Model RRK150 OB serial no. WS 1208816
Nov 25, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Food Mixers Logo
57 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
