Question about The Computers & Internet
I have car stereo with broken usb input. The usb will not read any device maybe pins is broken.I would like to know Soldering tips wire usb to the board
  • mike Apr 23, 2017
    Resolder USB contacts with new solder
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 85 Answers
Google that there are 4 pins 2 signal, plus and ground
Posted on Apr 23, 2017
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
My 1gb transend pendrive is show insert disk
hi Gagan,
please remove the covers carefully and check the soldering points of metallic parts and pen drive pcb some times the middle two pins are broken.
if yes you can re solder it with soldering iron and relevant soldering aids.or ask someone to do so.
then clean the printed circuit board with electronic contact cleaner.
most of the time i found the pen drives with broken pins.
Good luck.
let us know the results.
regards.
nuwan
Apr 06, 2013 | Transcend TS1GJFV30 - 1GB JetFlash V30 USB...
I'm trying to install a stereo but don't have the plug I would like to know how what pins are 12v pos. and which is my ground. Can u help
hi if you mean the wiring from the stereo your live is the red wire, your yellow wire is live when your ignition is on and your black wire is your earth, hope this helps
Mar 17, 2013 | Pioneer DEH-3200UB CD, MP3, WMA, AAC...
Logitech headset usb wiring diagram?
Is this what you are looking for?
Jul 10, 2012 | Logitech USB HEADSET H390
My flash drive is broken.........the end is broken away from the circut board. Can it be repaired?
Only attempt this repair if you need the information on the USB drive as they are fairly delicate devices inside.You should be able to repair it if you have the right fine soldering iron and good soldering skills as the printed circuit board tracks will be very fine: you will probably need to very carefully re-attach the USB plug to the printed circuit board with strong epoxy glue and then ensure that you re-join (with the help of extremely thin electrical wire if require) all the tracks to the 4 USB pins. The Electronic is very static electricity sensitive, so make sure that you do not ZAP it by first earthing yourself! Hope it helps and Good luck!
Jun 11, 2010 | Cameras
How can i deactivate the protect that blinks in my kenwood car stereo, the stereo i have is the kenwood kdc mp342u model
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
Feb 11, 2010 | Kenwood KDC-MP342U Car CD Player
Headset problem
The cord is most likely broken at either end. I'd say time for a new one but if you want to repair it and can use a soldering iron get hold of a 3.5mm stereo jack, - cut the jack end off of your headphones, strip back about 15mm of insulation to expose 3 wires and solder them
TIP: White is usually left ( it goes to the pin that feeds the very tip of the plug
Red goes to the middle- Right channel
The shield or the copper braiding that wraps around the outside is common or ground and it goes to the longest pin which often has a clamp to relieve the strain.
I would try to fix the plug end first as the headset end can be more tricky. If you can work out which end of the cord is the problem by wiggling it then you know which end to tackle!
Hope this helps,
Good Luck
Jan 17, 2010 | Logitech USB Desktop Consumer Microphone
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Tomtom one xl usb socket broken off main pcb
I have gone around this problem by removing the internal battery, and soldering a female power connector to it.I now it on 3 aa batteries, alkaline cells givbe me an autonomy of about an hour, maybe duracells will give a bit more duration.
When i have time ,I will work on splicing the wires on the cigar plug adaptor and use that as a permanent power source. The wires for the Lipo cell are Red positive, solder this to the yellow wire( probably a battery gauge wire) and black ground.
Hope this helps
Very poor workmanship from TOMTOM
Nov 13, 2008 | Tomtom One XL GPS Receiver
EPSON PHOTO PC 500 DIGITAL CAMERA
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
Computers & Internet Logo
55 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
