Question about iPhone Apps
Why don't I getmobdro anymore? When I go to app it says no result found
Found the best solution for Speakeasy and other transfer problems.
I just found the solution to my question. You need to go into DiskAid Preferences - Advanced and check the box for "Display all Apps even if they don't have their 'File Sharing' enabled." My whole list of apps became visible in DiskAid and I just clicked "Copy to Computer" and they moved over instantly into the folder of my choice. Thanks, marpa02!! I've been trying to do this for over a year!
Sep 24, 2012 | Zarboo Software SpeakEasy Voice Recorder
Error no. 302?
Control Panel / Administrative Tools / Event Manager
Windows 10 in startup apps go to Administrative Tools / Event Manager
Right Click start menu click event Viewer
once there look to left and expand WIndows Logs Click on Applications and wait for them to load See my pictures i found an error then I clicked on it and it told me what app.
If you don't have event viewer turned on you won't get anything. Then just google turn on event viewer your OS = (winodws 10, Windows 8 etc. turn it on reboot once the error occurs it is recorded go to event viewer and see results.
Dec 30, 2017 | Toshiba Satellite M45-S331 Notebook
I have problem opening my app for hanging friends...
If it hangs at the start screen of Hanging with Friends, then it just means that your software is outdated. It requires a higher OS, so make sure that you've upgraded to the latest iOS software that is on your iPhone, (the most recent is 4.3.3) and this shouldn't be an issue anymore!
If this problem still persists, then please make sure you have enough memory (delete applications you don't need, if possible!)
Jun 29, 2011 | Zynga iPhone Apps
I don't know how to cancel my subscription on facebook flirt app
Click account, and then privacy settings, and then look near the bottom and you will see Apps and Websites. Click "edit your settings", and then the button that sayd "edit settings". After that just look for the one that you don't want anymore and click the little "x" all the way on the right of it and click "remove" in the box that pops up. Then the app will be gone :-)
Jun 03, 2011 | Computers & Internet
It keeps freezing up and the touch screen stops working at times
Have you added any new apps recently? Thats the usual suspect for this. If you can remember which one try taking it out and see if it behaves then.
It can be also from something as simple as running out of ram or space. Some apps don't handle this well and you get lockups or temp freezes. And sometimes this results in corrupted files which cause it to happen or other problems. Delete anything you don;t use anymore and that will help. Doing a hard reset and then restoring your files usually fixes anything else.
It is rarely hardware related. You would see a lot of slow operation, and probably it would run warm or hot. Usually if its hardware they just stop.
Sep 07, 2010 | Palm Tungsten E Handheld
iPhone Apps Logo
292 people viewed this question
Top Apps Experts
ray gallant
Are you an App Expert? Answer questions, earn points and help others
