Question about Refrigerators
Mfd2561hes French doors model, control panel is dark and clicking noise coming from lower right rear, what does this mean?
  • Whirlpool
    Whirlpool Jun 16, 2017
    Hello Rita, we apologize about the frustration you have experienced with your Refrigerator. If you still need assistance, please provide your name, the name of the site you were contacted on (, your user ID name ( Rita Wittig ), your phone number, your address, the full model and serial number, and email the requested information to We would be happy to review your concerns further.
  • 163 Answers
The manual is here even with a wiring diagram
Posted on Apr 23, 2017
Maytag fridge right door won't stay closed
it may be necessary to reset the hinge adjustment to move the door further across the opening giving the magnets a better area to hold on to . there is a slight amount of adjustment in the mounting points of the hinges. You may have to replace the door gaskets as they become hard over time and the magnets cannot work properly in the hard plastic
Jun 21, 2013 | Refrigerators
2006 Chevy Trailblazer...the top "third"
Brake light problem - if bulbs and fuses (#34 and #43 in rear fuse panel) are good, then only other possibility are the circuit boards where all the tail lights are located.
Noise coming from rear is the mode control actuator in the rear HVAC unit, it is trying to move a stuck blend door.
Aug 06, 2011 | 2006 Chevrolet Trailblazer
Where can I find the model number on my kenmore elite washer?
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
MFD2561HES The fridge temperature wants to fall to from set temp 40 to 32. I set it higher and it climbs back up in time but will lower itself back down in a day or two. Why would it continue to cool...
The control board in the control panel should be regulating the air damper correctly. If the control board is responding this way the the damper is told to open too wide allowing colder temperatures into the fresh food section. The thermistor also may not be working properly or may and the board could be the total problem. This is going to be something that an Authorized Maytag Technician will need to have a look over. Switching the Control Board Part number W10207861 Temperature Control Board and 12002356 Thermistor just may solve this. Sea Breeze
Oct 23, 2009 | Maytag MFD2560HES Bottom Freezer French...
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Control pad not working. Some lights are lit but
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Get me the make and model number so I can help you better, Thanks, Sea Breeze
Mar 28, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFD2561HES Reefer not cooling
hello frooska,
kindly look at the back panel of the freezer section. if you can hear the humming sound, find out where it is coming from. if the sound is coming from the compressor, that means the evaporator fan is not running.
but, take note that u need to press the door switch of the freezer in order to check the fan. the fan stops every time the door is open. if the fan is not running, you have to remove the middle panel, above the evaporator, the fan would be there. ( in the freezer section)
but if the fan is running and the back panel of the freezer is full of frost, then that would be a defrost issue.
defrost heater, bi-metal or defrost controller.
Tnx 4 uisng Fixya,
Dec 16, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
