Question about IBM Office Equipment & Supplies
The back space button that erases what you just
IBM Wheelwriter 6
The back space button (at bottom right hand corner with an x)that erases what you just typed is not erasing-what to do?
  • 630 Answers
Check that the erase tape hasn't run out
Posted on Jul 24, 2009
How do i erase tabs on an IBM 6781 personal wheelwriter?
Try a little shot of WD40 on each side of the silver shaft that the carrier slides on,. If that doesn't work you have to lube the carrier motor bearings the front one is accessable from the inside the rear one you may be able the straw thru the release lever hole.
DickyO
Nov 05, 2014 | IBM Model 6781 Personal Wheelwriter...
Ribbon won't advance
First try a little WD40 on the ribbon motor bearings top and bottom, ckeck the plug that is plugged into it. The motor is under the R. corner of the ribbon deck towards the front of T/W.
DickyO
Jul 17, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter 6 typewriter hammer no longer strikes
It is pretty common for the pad on the solenoid to strike the keys wears out, and for the batteries to be dead for the memory. Your machine probably needs a good cleaning, oiling, and a new pad for the striker. about $100.00 in the shop.
Jun 30, 2009 | Office Equipment & Supplies
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
Feb 14, 2009 | IBM Office Equipment & Supplies
How do I clear the tabs on this IBS wheelwriter 1500?
Space the carrier all the way to the right, press and hold the tab clr key. press return this will clear all tabs rt. of the L. margin
Feb 06, 2009 | Lexmark Wheelwriter 1500 Typewriter
How do you replace the batteries on an IBM Wheelwriter 3
Look inside the case (lift the top cover) down in front of the keyboard on the bottom of the machine on the right sid is a black container slide it to the side and you can replace the battery
Dec 15, 2008 | Lexmark Wheelwriter 3 Typewriter
3 Lights flashing
The three lights flashing indicate the batteries need to be replaced.
Apr 08, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
Wheelwriter 3500
Press and hold thr code while hitting the RELOC key on the rt. side of the keyboard the lower rt. hand corner of the display will change to indicate spacing.
Nov 05, 2007 | IBM Wheelwriter 30 Typewriter
MARGINS
Move carrier to left margin press margin release, top left hand side of keyboard, back space to desired position and press L Margin key.  Margins will reset to default if batteries are dead.   Right margin simply space to whever you want the margin and press R Margin.
Oct 24, 2007 | IBM Wheelwriter 30 Typewriter
74 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
