Question about Refrigerators
Kennmore Elite Double Door Bottom Freezer Top of Cute under cube bin freezers up Preventing ice to dispense. How can we fix this??
    Sergeant:
  • 163 Answers
Posted on Apr 23, 2017
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Model PSC23MGMA BB GE side
Hi and welcome to FixYa, I am Kelly.
I think that the door flapper spring is broken or disconnected: PN WR02X10585
http://www.repairclinic.com/GE-Refrigerator-Model-PSC23MGMABB-ID-617640-Spring-Parts
It is item 63 of the below link BUT, it not listed in the below link so see above for ordering:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219346
If there is a problem with the solenoid item 36 above, it can also cause the frosting problem:
Sears parts direct also has parts for this unit here:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSC23MGMABB/0432/0165000/G0104039/00001?blt=06&prst=&shdMod=
I am sending this now and will look uo the crushed Ice problem and respond again soon,
Thanks for choosing FixYa,
Kelly
Posted on Jul 29, 2011
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Ice maker works fine and ice comes down but when it goes to crush the ice it wont crush it jams up
Remove the ice bin, examine the metal arm on the back of the bin. This arm needs to move up and down freely, this arm is the shifter for the cube and crush setting. Also look at the square hole in the back of the freezer where the bucket came out of, the shifter in there needs to be down all the way also.
With the freezer door open, depress the cube setting on the door, hold the light switch and depress the dispenser button, do you hear a click? If so the shifter works in the freezer and the problem in in the bin itself. With no model number given, I have to assume the ice bin is not in the door, its inside the top portion of the freezer section.
Good Luck
Nov 05, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite model number 795. my ice dispencer only gives crushed ice even though its set to cube
1st i would remove all ice out of bin, clean outBIN with warm water under sink. put ice back in do not throw away for testing purposes. if worked then a cube may have been caught in bucket chopper improperly . if didnt change anything could be a bad crusher solenoid. in home service could run you 90-145 dollars depending where you live. if you do it yourself crusher dispenser solenoid will run about 30-50 DOLLARS. hope this helps
Sep 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The icemaker in the door of our Kenmore Elite Trio frig just stopped working, exactly 13 mos. after we bought it. We did not get an extended warrantee, because we have never had a new appliance fail so...
Is the ice unit turned on? I pushed the off button by mistake and PAID someone to "turn it back on for me" The guy laughed all the way to the bank :( Also he said a good place to start , before I call next time, is have you checked to see if there is a ice cube frozen(caught) in the top.Pull out the ice catcher(bin) and check for the frozen cube of ice. Be sure to turn off the ice maker first or it may drop ice when you least expect it! My fridge is the origional for house (18 yrs) and after I've done this check list, the problem is fixed. Just thought I mention it. Good luck!!!
Mar 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
