My screen has moved to one side. I can't get to minimize or close. How do I fix that?
I think I touched some key or keys.
  • Dana Taylor Apr 23, 2017
    Hi Cecilia Bahr-Thex, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    My email jdtaylor@live.ca
    sir jdtaylor@live.ca
  • mike Apr 23, 2017
    Reboot in safe mode and back to normal mode looks like monitor or graphic driver issue.
SOURCE: the touch screen of my lg chocolate vx8500g is not working
Your phone can be "REPAIRED" by LG if it is within the first 12 months of purchase. After that, from the manufacturer, your on your own. I have a phone a friend gave me to switch over to. My contacts are all lost. :(
Posted on Jan 29, 2008
  • 6 Answers
SOURCE: touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Posted on Jun 25, 2008
SOURCE: keys of k550i not working
try switching it off and restart it and c if keys works else remove the panel and blow some air over it wipe out the dust over it and check
Posted on Jan 13, 2009
  • 97 Answers
SOURCE: my touch pad has frozen on my siemens amilio L7300
generally using the windows key, the arrow keys, "tab", "enter", the spacebar and "alt" are enough to get around.
Posted on Oct 27, 2009
  • 83 Answers
SOURCE: inspiron 1300 screen border 1 inch
Have you tried adjusting the screen resolution? If you are running windows, try right-clicking on the desktop, then going to properties>settings>screen resolution. Set it to maximum available (I think it's 1024x768 on your inspiron). This should sort it out.
Good luck,
Raf
Posted on Nov 09, 2009
Dell inspiron right hand margin cut off
It is more likely that the window got moved to a point where the x, restore, and minimize buttons don't show than it is that a portion of the whole desktop is cut off. Right-click on the icon that represents this window in the task bar, and click maximize. If that's not an option, choose move, and then use the down and or left arrow keys to reposition the window where you can see the minimize, restore, and x buttons, and then hit enter on the keyboard.
Mar 02, 2012 | Computers & Internet
The keyboard doesnt work properly. when i type it moves around the screen and randomly closes things down
it seems that any key is stuck in the key board, if you can open it & clean the membrain it may fix the problem or you can replace the key board.
Sep 26, 2011 | ASUS Eee PC 904HD
How do i close my browser window
You can close your browser window by clicking on the red "x" in the top right hand side corner of your screen. The red "x" means "close". The "square" in the center next to the "x" means make "bigger". The - key next to the square in the upper righ hand side corner of your screen means "minimize". "Minimize" means bring the window to the bottom of the screen. It's like tucking it away or hiding it. If your window is full size and you click the minimize button, it will make the screen a smaller square in the center of your monitor. If you click it again, it hides the window at the bottom of your screen. You can see which windows re open by reading the labels at the bottom of your screen. To bring a screen back up to regular size when its minimized on the bottom - just click on it with your mouse.
Mar 03, 2011 | Mozilla Firefox
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
My toshiba laptop cursor doesnot move when i touch the tray pad
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
Jun 13, 2009 | Acer Aspire 5610-4648 Notebook
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
IBM WHEELWRITER 5
You probably have the right margin set to close yo the lrft and have auto return on. To turn off auto ret. hold the code key and touch "R". To move the margin tab to the rt. side and touch rt. mar. key.
DickyO
Jun 30, 2008 | IBM Wheelwriter 30 Typewriter
My sansa e250 it doesn't work
chech out for the lock key at he top at side of the earphone port.. it is lock key move it to unlock
May 09, 2008 | SanDisk Sansa e250 MP3 Player
P200-RT3 Toshiba Note Book - Windows Vista
Yes, there is a way to shut down without touchpad. Look to see if you have a key on bottom left corner of keypad that looks like a little MS Windows icon (kinda like a 4-piece "crooked flag"). If you do, you are in luck. Press that key ONCE and let go and the start menu will "expand" and show you programs, settings and SHUT DOWN. Now just hit the UP arrow key (on bottom right side of keyboard) and the menu moves up one notch, to SHUT DOWN. No press ENTER and the shut down menu appears Move the arrow key again, until it says "SHUT DOWN and press ENTER again. That is it.
If you have no windows key (many laptops don't) then try pressing ALT and F keys. Sometimes this works. If it does raise the menu, then 5the instructions are the same thereafter (arrows and enter).
Another way to shut down is press CTR ALT and DEL (DELETE) together, all three keys simultaneously (but only ONE time). Then wait a second. This brings up a process window that has tabs for shut down (arrows and enter will work there too).
Now, when you restart, look for an icon in bottom right hand corner for "synaptics touch pad". or some other brand touch pad. There you can change your touchpad settings back to "tapping" for mouse clicking. You can also allow "click and drag" but I think that is dangerous, since you can accidentally "bury" files and folders.
Hit the solved/Fix Ya key on the way out. :)
Nov 11, 2007 | Compaq Presario Notebook
Screen minimizes when using the touch pad
If you touch the top right corner of the touchpad, it restores down the window you are currently in. The bottom right corner of the touchpad minimizes the window you are currently in. The bottom left corner of the touch pad brings up the start menu.
Nov 05, 2007 | Toshiba Satellite A135-S4427 Notebook
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
