Question about Garden
I have just purchased a 450e and decided to clean the chain and can't get the cover back on properly
    Sergeant:
  • 163 Answers
The 450e brings up chainsaws to lawn tractors and backhoe.
The parts and FAQ are found at this link:
http://www.ereplacementparts.com/husqvarna-450-200709-chainsaw-parts-c-114486_114487_114592.html
Sir Dana Taylor
jdtaylor@live.ca
Posted on Apr 23, 2017
3 Suggested Answers
  • 2239 Answers
SOURCE: what is the standard drive link on this chain for 450e series saw
The drive link count is 72 for an 18" chain
Posted on Jan 19, 2011
wentlanv
  • 710 Answers
SOURCE: how to check for proper chain tension husqvana
You should be able to move the chain with your hands, but not too easily. Please wear gloves when doing this. Also, if you pull the chain away from the bar at the middle of the bar, there should be no more than 1/8" between the bar and chain.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 24, 2011
Testimonial: "very helpful"
I adjust my Jonsered chain to the proper tension,start her up and rev the motor and the chain goes bar tight. U can hear the strain. I re adjust and it starts all over again. Whats going on
did you check the chain brake is not activating, you should be able to pull the top handle back and chain goes free to push forward and irt will lock the chain. do this with not running first. is the cover on properly with the chain lock mechanism loosly sliding over the steel clutch wheel. clean out any wood dust n chips from inside the cover. hope this helps.
Nov 05, 2016 | Garden
Let my 450E husquarna run out of oil now the chain wont turn
Remove the bar with the chain and with gloves on see if you can pull the chain up out of the bar. If it comes out oil it up, put it back together, ad try running it.
Oct 30, 2013 | Garden
I do not know how to replace the chain on a husquavarna 450e chain saw and no one is willing to tell me how to do it.
Before replacing a chain saw chain you must ensure that you disconnect the sparkplug lead. Remove the chain saw cover which is located at the motor end using the tool that came with it. A spanner socket remove the 2 nuts that are the same size and that will loosen the chain arm and chain itself. Note the direction of the chain teeth as the new chain must go back in the correct manner . Now reverse the installation the same way you remove it. After replacing the chain you need to tension the blade allow about a 5 mm slack and there is a tension screw located to the side of the cover you removed. Again it's best to refer to a authorized dealer if unsure.
Jul 15, 2011 | Garden
I can't get a replacement chain back on the bar on
The 450E is a tooless system, make sure the brake is off by pulling the handgurd fully back to the top handle, flip up the lever on the big grey fixing nut, undo counter clockwise, wind the grey knurled adjuster wheel facing out of the cover fully back, remove the chainbrake side cover, push the guide bar fully back toward the sprocket, you now have enough rome to replace the chain onto the guide bar rails, now re fit the side cover, make sure the adjuster pawl in the cove aligns with the adjuster hole in the bar, re fit the big fixing nut finger tight, wind the adjuster wheel down to re tention the chain, when the chain is snug all the way around the bar tighten the nut fully.
May 29, 2011 | Husqvarna 450 e-series 18" Chain Saw
How to check for proper chain tension husqvana 450e
Handie Andie
Apr 24, 2011 | Husqvarna 450 e-series 18" Chain Saw
Oiler is not working on 450e.
Remowe right cap and cutting blade clean the oiler. If dont help check oil tank and clean it check oil tank cap teher must be air inlet is it clean.
Nov 10, 2010 | Husqvarna 450 e-series 18" Chain Saw
Cannot move the chain by hand after the bar has been tightened.
First be sure the chain is on going in the right direction. When looking at the bottom of the bar the sharp tooth should be going towards the motor. When you put chain back on are the chain teeth properly engaged in the sprocket on the motor. Remove the cover again, check that teeth are in sprocket. Make sure pin from adjuster screw is engaged in the hole in the bar. Before you tighten the cover bolts, make sure chain will turn by hand. If not adjust the adjusting screw. Once adjusted, tighten cover bolts. Check again after tightening bar.
Jul 04, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I just got a husky 450, not a 450e. im looking for a 20in bar and am havin hell finding one. all i can find is 20 inchers for the 450e.? ?
according to Husquvarna the 450 and the 450e use the same bar.it's just a differant tensing system used. bar number from husquvarna is 508 92 60-80 that's for a 20" bar
Feb 20, 2009 | Husqvarna 450 e-series 18" Chain Saw
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
