Question about Garden
How do you remove and replace primer bulb - Garden
    An expert who has written 3 tips or uploaded 2 video tips.
  • 126 Answers
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
This isn't the exact model but close enough. Marked as page 20 but its page 17 on the PDF file. Looks like its 2 screws holding the primer on and 2 pipes going to the primer. Should be an easy replacement.
Mar 27, 2016 | Craftsman Sears Chain Saw Manuals Model...
How to replace the primer bulb
Gain access to carb and right by the bulb you will see about 4 screws holding down a metal plate that holds down the primer bulb. Remove the screws and plate and replace damaged primer in same spot, and screw plate back on.
Nov 26, 2015 | Stihl Br550 Br500 Backpack Blower Fan...
How do you replace primer bulb on model 917.385125 B&S 550 series motor on a Craftsman mower?
the old primer ball is held in place with a round retaining clip remove it just use a sharp screw driver to pry it out then pull out old primer buy new primer and retaining clip put primer in the take a socket that is the same size as ring and that will slip over the primer push the ring in till it seats
Sep 13, 2014 | Craftsman Garden
How to replace carb. Primer?
If you don't see two screws diagonal of each other than there is a little ring holding in your primer bulb. Be careful when removing ring as to not bend out of shape usually new primer bulbs don't come with them. If there are the two screws diagonally, than just unscrew and lift holding plate remove old primer and reverse for install... Good Luck....
Jun 20, 2014 | Toro Lawn Mower With Toro Power Tools
remove the two screws on either side and take the ring off and the thimble looking bulb pops out then replace in reverse.
May 14, 2012 | Garden
How do i remove the primer bulb on my homelite mighty lite 26cc blower
The primer bulb should be attached directly to the carburetor. There will be a plate with 4 screws, once on each corner, which you will have to remove to get the primer bulb off of the carburetor. You can find replacement primer bulbs at
Sep 29, 2011 | Homelite Mighty Lite Lawn Trimmer
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Jul 06, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
