Question about Samsung Heating & Cooling
Samsung split ac display show e3 blower is not working I have checked blower motor mother is working
  • 534 Answers
SOURCE: ac blower motor
Check fuse supplying fan is not blown,
Check blower control switch is operating OK,
Check relay controlling fan is operating OK,
Check variable speed resistor pack is not faulty (the resistor pack is usually located in the blower ducting, in the blower airflow),
Check blower motor ground connection is not missing.
Posted on Aug 13, 2009
  • 19 Answers
SOURCE: Heater Blower won't work
There was a bulletin reguarding water contaminating the blower motor, which overheats the blower resistor and renders it inoperative. The fix was to replace the blower and the resistor and seal the culprit hood cowl screw at the base of the windshield, which is the second screw from the passenger side. They say water drips off of it down into the fresh air opening.
Here's what I'd do: Assuming your switch and blower motor is good, replace the blower resistor. Remove the blower motor and see if it spins without any excessive drag. If it's okay, reuse it. If it's dragging, it will overheat your new resistor in a short period of time and you'll be back at square one. The blower resistor is mounted to the front of the case with 2 screws to the left of the blower motor. Remove the glove box and you'll see it.
The Hood cowl screw is straight down into the cowl, the second one from the right side, about 10-12 inches from the right fender. Pull it out, put some sealer on it, and reinstall it.
Posted on Oct 02, 2009
YellowNo5
  • 268 Answers
SOURCE: 1990 honda accord ac blower motor will not work
Check 7.5 fuse (#8) inside the car by your left foot and check the 30 amp fuse in the engine compartment (according to your diagram on the inside of your fuse box lid).
You can replace the fan motor pretty easy but you'll want to unplug it and test it first by running an automotive battery to the plugs of the fan with 2 jumper wires. The fan is above the right foot of the passenger area. There are three 8mm screws to remove then it drops out. Careful with the wiring.
If your fan is still good, you'll have to consider removing your knob and switch assembly to see if something is unplugged in there. Good luck.
Posted on Oct 03, 2009
  • 1757 Answers
SOURCE: 2003 dodge durango front heater/ac blower motor
Check the Blower Motor Resistor. This controls the Blower Motor/Fan Speed.
Posted on Dec 27, 2009
SOURCE: My sairon split system ac unit does nothing and
if split ac display shows e3 what is the solution for that problem
Posted on Jan 13, 2011
My Samsung ac display shows E3
indoor fan motor i defective need to replace
Aug 02, 2016 | Samsung Heating & Cooling
Electrolux split A.C. display F6 error and trips immediately after starting the compressor.
Anti high temperature protection.
Check the outdoor coil for airflow obstructions.
Check the outdoor fan motor for correct operation.
May 23, 2016 | Electrolux Heating & Cooling
E3 display on lloyd make split ac how to solved problem
Pipe temperature sensor checking channel is abnormall [E3]
Check Out Manual _ http://www.mylloyd.com/productpdf/AC.pdf
May 13, 2013 | Heating & Cooling
My voltas split AC did not work and shows E3 in the display. i try to change mode but no use
power indoor and outdoor units down record all info in and out make m# s# froward to me ..also need history of unit when installed past problems.
Jul 03, 2011 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
Dec 10, 2010 | Heating & Cooling
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Frontload washer will not complete a load..shows E3 on display
e3 is a motor sensor not reading the motor properly un plug the unit for 5min and try it that will clear it but you may need a new sensor check the connectors at the motor sensor
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Heating & Cooling Logo
27 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
