Question about Kyocera Office Equipment & Supplies
Kyocera FS-1135 will not send fax out. Has worked great for 4-5 years and just stopped working. It receives fax just fine. Everything else works fine.
We've had it 4-5 years and it was working and now it will not. Do not know of any settings that were changed. Today printed a FAX TX Report and starting 4-19 til now there were 24 attempted fax and only one went through. All phone/fax numbers were lines that we send regularly too. We called one with a phone just to make sure the call was getting through and the fax machine was on. It was and it made the fax tones. It receives fax just fine. Another (our "back-up" free standing fax machine) used by other staff, works fine. Both of the fax machines are on the same phone line (along with the credit card machines) and everything is working except the sending out fax from our FS-1135 work. I hooked a phone to the copier and was able to manually dial out and could hear the fax machine on the other end. I tried to turn the sound on on my copier/Fax but I don't know if I did it right. I could get no sound out of it. When I attempt to send a fax, here's what happens. I put the Page that I am going to fax in the auto feed tray. I push the Fax button and it lights up. Then I type in the number of the other office's fax machine. Then I hit the Green button (START) and it feeds the page into the copier and says it's scanning - then the Memory light blinks on and off 2 times - and then everything stops. The display screen say: Enter destination or Ready for Fax - and it sits there about 5 minutes and it prints out an "Error Occurred" and say "BUSY"
2 Suggested Answers
SOURCE: Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
Posted on Jun 19, 2009
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
May 26, 2015 | Kyocera Office Equipment & Supplies
Why i cannot send a fax from my kyocera ecosys fs-1135 mfp?
If you can receive but not send, maybe the number you are sending to should include some pauses, especially at the end of the number. If you have a good dial-tone when you do "On-Hook" then there is nothing preventing you from sending on the machine end. Has the phone system just gone digital? You may need a filter to translate pulses properly. Can you call your cell-phone using On-Hook dialing? I would say there's nothing wrong with the machine. But you'll get blamed for the communication problem in any case. Try manually dialing using On-Hook dialing (turn your Monitor sound up high) and listen for some kind of message. It's a number or line problem. Did they just start requiring an 8 or 9 to be prefix-dialed to get "out?" Or stop requiring it? Maybe there is a prefix number programmed through the default menus that you don't need anymore.
Sep 06, 2014 | Copystar Kyocera FS-1135 MFP/DP Printer
How to find the fax number for my kyocera fs 1135 mfp
fax your cell phone the number that calls up is the fax number
Jun 15, 2014 | Kyocera FS Office Equipment & Supplies
Kyocera fs 1135mfp cf000
It's most likely a hard disk error. Try getting the HDD replaced.
Dec 19, 2013 | Kyocera Mita Office Equipment & Supplies
I've refilled Kyocera FS- 1135 mfp then not genuine toner had detected.. but the toner i used is kyocera compatible toner and its working to other kyocera machines.. Is it because of the IC chips or what?...
Kyocera compatible does not mean Kyocera genuine. Not using genuine toner can invalidate your warranty. If that doesn't bother you then the printer detecting a non-genuine cartridge is not an issue.
Sep 02, 2013 | Kyocera FS Office Equipment & Supplies
Search Fixya...MIta 3140 wont receive faxes
make sure your phone line is plugged into the LINE jack, not the EXT jack
Jul 16, 2013 | Kyocera FS-3140MFP Mita FS-3140MFP 42 PPM...
Copystar Kyocera FS-1135 MFP waste toner full
I can not find the screw razor is talking about.
Mar 05, 2013 | Copystar Kyocera FS-1135 MFP/DP...
81 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
