Question about The Computers & Internet
Rewrite this sentence ithout changing the meaning..... In southern Africa, antelope species show seasonal birth peaks timed early during October-November, around the start of the rains
Suraido
  • 195 Answers
SOURCE: when it rains my 1999 gmc doesn't start.
Usually a telltale of ignition problems. Usually the spark plug wires insulation is gone bad and humidity causes the spark to jump before the plug and thus, prevents the plug from firing. If the wires are OK, then probably the ignition coil's casing is cracked or open somewhere. If the coil(s) is fine (on some engines there is more than one ignition coil), also check the distributor for cracks on its body or cap, and open it up to check the condition of the water seals inside the distributor unit. Should be one of the 3 problems mentionned above, if not, get it checked by the dealer cause it will be some weird problem with the onboard computer or some of the sensors on the engine.
Posted on Jul 08, 2009
SOURCE: The date is showing as Sunday 1 November 2009
Problem fixed. I removed the battery and allowed the phone to do an auto adjust for time and date when it was turned back on.
Thanks anyway.
Posted on Oct 11, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Hi I have 2 inverters on my house each with 21
The inverter will only make AC at a rate per the current and voltage being supplied by the solar panels. The panel outputs need to be checked and compared to the panels that are working correctly.
It certainly sounds as if there is a power distribution problem from the panels supplying the 3100 W average output inverter. It can be anything from a corroded terminal to a damaged umbilical or anything in between.
A bad ground for the inverter will also limit output. It may read resistance / continuity but can not carry the amount of current needed to produce 3100 W output. Given it has only been 5 days the problem should not be hard to isolate and find.
I had a similar problem arise quite recently with an 18 panel system and the problem ended up being corrosion on a terminal block connection. Cleaned up the terminals and reconnected everything with a 2155W difference from the original output on a 3200W inverter system.
Thanks for using FixYa.
Kelly
Posted on Mar 20, 2010
closerfan
  • 49 Answers
SOURCE: I have not received a
Have you tried calling the telephone number on the back of your credit card? The website may also have some telephone numbers to use as well.
On these types of disputes, I like to write a letter directly to the credit card company giving all of the information you listed above plus the steps you took to try contacting the company in order to resolve the matter. Usually suggesting that you might close your account is enough incentive for the credit card company to get moving on giving you the money owed.
Good luck.
Posted on Jan 01, 2011
  • 414 Answers
SOURCE: I purchased two 44 inch
Have the wiring checked by an electrician. Your wiring may be aluminum and occasionally the wire nuts (which are special for this type wiring) will fail. They are purple in color. Also check the wattage of the bulbs, If you have exceeded the wattage rating of the fan it will heat the rubber bands around the glass ware excessively.
Posted on Feb 14, 2011
Where is the king snakes habitat ?
RANGE: Kingsnakes have one of the widest distributions of any American snake. They range throughout the southern United States and Mexico. The Eastern sub-species can be found as far north as southern New Jersey and as far west as southern Alabama. HABITAT: Pinelands, hardwood hammocks, prairies, marshes, and estuaries
quote from: https://seaworld.org/Animal-Info/Animal-Bytes/Reptiles/Eastern-King-Snake
Kingsnake Facts News on Kingsnake classifications
Dec 16, 2016 | Reptile
Rewrite the sentence with the correct concord Diamonds is mined in South Africa.
the verb is should be are as the noun diamonds is plural
so it should read --Concord diamonds are mined in South Africa
Dec 16, 2016 | GPS
How You Can Get A Cheap Flight Deal For Honolulu This Time?
You can get flights to Honolulu from all major American airports including north and South America. Also you can get cheap flights from many international destinations such as Canada, United Kingdom, Australia, South Africa, New Zealand and Singapore. The peak season of flying to Honolulu starts from December to April when all country's weather goes to its worst condition. During this time the prices for flights and other tour amenities goes higher and it gets hard to get a booking with the renowned airlines on that time. From April to December it's the off season but the island get busy during the Japanese Golden week when the place get over-packed with Japanese visitors.
The climate of this place range around 60-80 Fahrenheit however it depends on the season. There are two main seasons you can experience there, rainy and dry season. The rainy season is from November to March where the rest of the year goes dry. Once you reach this city you can visit many of its famous places such as Arizona Memorial Museum, Bishop Museum, Botanical Garden, Byodo-In Temple and the historic China Town. You can use the public bus or Waikiki Trolley to getting around the city. Also renting a car is a good option and you can get that in a reasonable price.
Flights deals to Honolulu
To get cheap flight deals to Honolulu, you must book the tickets in advance to avoid any uncertain circumstances. You can get cheap tickets online by exploring all leading international flight websites. The chances to get cheapest deal are more when you book it 2-3 months earlier from your journey dates. The flights are quite long so it's better to book a comfortable seat while flying and you can get that in cheaper rate if you book in advance. And early bookings not only get you cheap Flight to Honolulu but also you can get plenty of time to arrange all other vacation staffs.
Visit - Cheap Flight Tickets to honolulu1 888 701 8929 Online Low Cost Flights to...
Jul 25, 2016 | Luggage & Travel
Where do zebras live
Though they all live in Africa, each species of zebra has its own home area. Plains zebras live in the treeless grasslands and woodlands of eastern and southern Africa. The Grevy's zebra lives in in the arid grasslands of Ethiopia and northern Kenya. The mountain zebra is found in South Africa, Namibia and Angola.
Feb 23, 2015 | Office Equipment & Supplies
Where is the comma splice in this sentence? This tutorial was a good exercise to identify run-ons and comma splices, however, it stated there were several different ways to rewrite each sentence. I on
Where is the comma splice in this sentence? This tutorial was a good exercise to identify run-ons and comma splices, however, it stated there were several different ways to rewrite each sentence. I only found one by breaking the sentences down to two sentences for each with a period separating the two sentences. Did anyone else find different ways to write the sentences other than the example I gave?
Nov 28, 2014 | Cars & Trucks
Can I load on South Africa Maps
Yes, you can load the map of "southern Africa" which includes South Africa. Go to the tomtom website ... click Maps ... look for "Map of the World" ... and look for Southern Africa.
Then you can purchase the map ...and, download it to your TomTom ...
Jan 15, 2014 | Tomtom ONE XLS Car GPS Receiver
Is there a specific time to put up birdhouses?
in theory yes as you want to put up the birdhouse in the nesting
season and each bird has a different season so you need to look it up.
But even if you don't get the season right, the birds can use the
birdhouse as a shelter.
Dec 25, 2013 | Garden
Can I use electronic calls and electronic decoys to hunt game species during open seasons?
It is illegal to hunt waterfowl, wild turkeys or deer with electronic or battery powered decoys. It is illegal to use electronic or battery powered calls for waterfowl, wild turkey or deer. Restrictions do not currently exist for other game species.
Jan 17, 2013 | Hunting
Computers & Internet Logo
52 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
