Question about LG Audio Players & Recorders
LG Soundbar Model NB3730A The power comes on and shuts off. The soundbar no longer gets to the menu. Just shows a small red light than it shuts off.
SOURCE: dvd unlocking for brand new Philips Soundbar HTS6100
Figured it out unlock for HTS6100, it's the same as for HTS8100
1. Turn on
2. Press Eject
3. Press 9, 9, 9, 9, 0
4. Swtich it to standby
5. Turn the player back on & it should now be region free.
Posted on Apr 05, 2009
smarthome2
  • 1114 Answers
SOURCE: Sony HT-CT100 soundbar + STR-DG720 = Yes misery, no audio
It's not going to do whayt you want. On the premise that you can't run a dedicated receiver to a dedicated receiver. One processor is not going to override another. The soundbar is a "self contained" closed system. Much like Bose products. I understand what you are looking for, it just can't be done with this product. Options: replace the sony soundbar with a passive polk soundbar or similar and keep the AV receiver or: Return the AV receiver and use the nice, but limited sony amplified soundbar. Hope this helps
Posted on Jun 25, 2009
bob_computer
  • 3153 Answers
SOURCE: I just bought a nexxtech usb powered soundbar
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Posted on Nov 01, 2009
SOURCE: my soundbar (Phillips hts8100) freezes on low pwr standby.
hi
i have also same problem, by that time i am pressing tv/ disc button then it should be okay
Posted on Nov 24, 2009
SOURCE: Purchased LG HLB54S Blu-ray Soundbar - I would like Multiregion
Just got the software to unlock it. It you dont have please let me know your model so I can send you the file. Quite big though.
Posted on Apr 17, 2010
HOW CAN I MAKE A HARD RESET FOR AN LG SOUND BAR WITH CODE NB2420A
To do a hard reset for LG soundbar las450h or 550 series, long press the volume min button on the soundbar and sound effect button on the remote simultaneously for 10 secs and the soundbar screen will show reset mode. Switch off and switch on the soundbar.
Jun 02, 2016 | LG NB2420A 160W Sound Bar
SOUND BAR IS ON BUT SUBWOFFER DOESNT WANT TO TURN ON RED LIGHT IS ON BLUE LIGHT NOT ON
turn the soundbar off, then press and hold the reset button on the back of the subwoofer until the blue light starts blinking fast. the point the remote at the soundbar and hold the mute button until"ID SET" shows on the display. Then turn on the soundbar and it should find the sub and pair with it.
Sep 12, 2014 | Samsung HWE450 Wireless AirTrack Sound Bar
Optical out not working with LG sound bar
got same problem the LG sound plate works with bluetoth mode but don't not detect the pioneer tv set..
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
Unable to use lg42pq3000 with lg soundbar
You have to direct the audio out on the tv to the optical output in the setup menu
Jan 01, 2014 | LG 42PQ3000 42" HDTV Plasma TV
How to set up LG NB2020 40W Soundbar
Connect optical cable to soundbar and tv. Plug in the soundbar.
One gotcha -- the red light on the soundbar means the power is off. No light means the power is on.
Jan 16, 2013 | Audio Players & Recorders
I have just got a 55 led 3d smart lg tv with tibo stand and soundbar i cant connect it to my tv as the tv doesnt have a red/white output i connected it through a headphone jack and all its doing is ma
If your soundbar has the input for a toslink, which is an optical sound input you may need to go this route. You will know it by seeing a very small flap with a red light emitting from behind it. Most newer tvs only have this output for sound anymore. Check Amazon for a toslink cable.
Dec 07, 2012 | Televison & Video
Connecting an LG soundbar to non optical digital tv
I'm pretty sure your soundbar has more than 1 input. Check your manual. There probably is AUX input on soundbar and that will allow you to connect to TV, assuming that your TV has any audio out. It could be either white and red RCA connectors or headphone jack.
Mar 07, 2018 | LG Audio Players & Recorders
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
