Question about Pool & Spa
Having trouble getting the filters to come loose to clean them, is there an easy way to do this while the spa is full?
3 Suggested Answers
2coolrick
  • 560 Answers
SOURCE: having trouble in putting filter back after omega
Try inserting it into the back first, then the front. One side is spring loaded and the filter has to be inserted against the spring first, and depressing it, while the other end is pushed up into the filter frame and released to secure it in the frame.
Posted on Jul 31, 2009
SOURCE: I am having trouble getting the rubber brake line
Loose from the brake tubing?
Liquid Wrench and a flair nut wrench
on tubing nut/connector
Can try a hair dryer to heat it,
no open flames
Posted on Feb 09, 2011
Leisure rite spa has fault code f2
The F2 Error Code is usually from a Balboa sp pack / system and normally is referring to a flow issue in your hot tub.
The usual culprit is a dirty filter, so make sure to either replace or give your hot tub filter a good cleaning. Also look at your intakes and out takes and make sure they are clear of debris.
We have a filter cleaning guide located here:
http://bathandspaparts.com/filtercartridgecleaning.aspx
You should also first cut the power to the unit and let it cool down and then reset it.
If this doesn't clear the problem up, you are probably going to need to start looking at water flow restrictions, such as air bubbles in the piping. A good flush will usually clear all of that out, without having to crack open any of the plumbing.
Last but not least, if none of that works, you are going to need to start looking at fuses, heating element, or the circuit board if all other trouble shooting does not fix your error.
The best advice here is that if cleaning or replacing the filter doesn't solve it, and then flushing out the system doesn't work, call a spa tech and have them come out. Unless you are a qualified spa tech, messing with the heater or circuit board is usually not advised.
Hope that helps.
Mark
Bath & Spa Parts Online
http://www.bathandspaparts.com
Jul 19, 2016 | Pool & Spa
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
Having trouble with water out jet. hardly feel any pressure. checked hose,etc.
if sand or DE filter backwash till water is clean if cartridge filter clean filters if that doesnt work check to see if impeller is clogged
Jul 13, 2014 | Intex Pool & Spa
Spa fault codes my spa is flashing ecn code and not warming up
check to see if pressure switch has power to both sides if ok it is working then, take off pressure switch to see if line is clogged
Jul 08, 2014 | Pool & Spa
Low flow message on balboa 500z system
The low flow message on any Balboa means that you are having an issue with the flow of water through your heating unit. This can be caused by a few things.
  • Low water levels
  • Dirty filters
  • Something is impeding your water flow
Top up your water level and make sure it is where it needs to be, clean your filters or replace them, and check that nothing is impeding your water flow at the skimmer or water intakes.
Here is a link to water flow issues.
F2 Error Code Trouble Shooting
Dec 24, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hi I am having trouble getting consistent power. I have taken it apart and cleaned it thouroughly only to find that the problem still remains. Any suggestions?
Try bumping the filter. You might have D.E. coated with normal accumulation of pool dirt, algae, etc. Your pool filters pump strainer or skimmer baskets could be clogged. Make sure there are no obstructions in your impeller. Finally, check the cover gasket, hand knobs, hose, clamps, etc. Replace or tighten as necessary.
Jul 03, 2010 | Hayward EC-40 DE Pool Filter with pump
Spa heater
You probally hear the fan at start up. If the heater won't fire the unit will shut down. This is probally an ignition problem or something in the safty circut. If you have your book on this it should have a trouble shooters guide. If your not comfortable with a box full of fire you may want to get a service person out.
Feb 10, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a brand new hayward filter for an in ground pool. The system uses D.E. The problem I'm having is after it's running for approx 30 minutes it looses all pressure. I've tried back washing it...
you might change out the D.E. media. you can also run it without any media to see if it looses the pressure after 30 min. mor than likely it is just time to change.
May 24, 2009 | Hayward Pool Products 55 Sq Ft Easy Clear...
Im having trouble opening the sring clamp on the hayward pool fil
once the ring is unthreaded it may need a good hard tug to open the filter lid.
Feb 01, 2009 | Hayward Easy Clear 40 Sq Ft Cartridge Pool...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
